Shorted During Voltage Checks [Solved]
ssenesy · 4163
Reply #15 on: February 26, 2015, 01:40:43 PM
Oops, I'm mixing up threads a bit with that one.
In any event, I would test with another tube to see if T5 drops.
Offline ssenesy
Reply #16 on: February 26, 2015, 02:55:44 PM
Well, tube rolling was on my to-do list, so I guess I'll get some on order now.  Makes sense to have some backups, just in case  ;)
Out of curiosity, what brand of tubes typically come in the Crack?  There was a piece of masking tape on the 12AU7, but nothing legible and no printing on the glass.
Thanks again!
Stan
Reply #17 on: February 26, 2015, 03:39:47 PM
Usually RCA, GE, or Sylvania, with an odd sprinkling of others here and there.
Offline ssenesy
Reply #18 on: February 26, 2015, 03:42:50 PM
Thanks Paul.
I ordered a RCA cleartop 12AU7A, a Mullard ECC82, and a Svetlana Winged C 6AS7G.  Should help for troubleshooting at least  :)
Offline ssenesy
Reply #19 on: March 04, 2015, 03:13:25 PM
The new tubes came in the mail Monday, and I've been anxiously awaiting the opportunity to try them.  I finally got some free time tonight and swapped in the RCA clear top 12UA7 and removed the jumper that I'd put in from A3 to A8.
As soon as I powered up to do the voltage checks, I knew something was different.  The heater on the 12AU7 was much stronger than before.  All voltages checks were good.  I tested the tip voltage and that stayed at zero.  So, hook up the DAC and listen to some tunes!
I'm now happily enjoying some Van Morrison and wondering how long it'll take me to go through and re-listen to my entire collection.  The clarity is amazing and the background is absolutely black (without the Speedball).  I've got the Speedball built, and will probably swap it in after a week or two.
Mark this one solved!  Thanks Paul.
