News:
February 28, 2021, 02:21:41 AM
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Bottlehead Kits
Eros Tape
Shunt Regulator A side C4S A end problem
Pages: [
Author
Topic: Shunt Regulator A side C4S A end problem (Read 2081 times)
YUL400
Jr. Member
November 23, 2014, 05:20:07 PM »
Hello,
I've just performed Final Voltage Check on the Eros Tape Preamp and Shunt Regulator A side, C4S A end, doesn't light up. OA pad Voltage is 220 volts instead of 170 volts. LEDS are checked. Any idea ?
Thanks.
Logged
Global Moderator
Hero Member
Re: Shunt Regulator A side C4S A end problem
Reply #1 on:
November 23, 2014, 05:24:51 PM »
Does the same voltage appear at the tube socket to which it is connected? If not, check the solder joints. If so, post the rest of the voltages.
Logged
YUL400
Jr. Member
Re: A Shunt Regulator A side C4S end problem
Reply #2 on:
November 23, 2014, 05:46:56 PM »
Exactly the same voltage. OA excepted voltages of Shunt Regulator A side C4S are all OK.
Logged
Global Moderator
Hero Member
Reply #3 on:
November 23, 2014, 07:06:17 PM »
The problem is probably not in the voltage regulator board, so we need the rest of the voltages. You can start with the 6922 socket voltages if you like, that has a good chance of leading towards the problem.
Logged
YUL400
Jr. Member
Reply #4 on:
November 24, 2014, 02:59:09 AM »
Hello,
6922 voltages at C1=220V, C2=100V, C3=103V, C4=7.7V, C5=0, C6=163V, C7=100V, C8=100V, C9=0
Logged
YUL400
Jr. Member
Reply #5 on:
November 25, 2014, 06:49:15 AM »
Do you want more readings ?
Logged
Global Moderator
Hero Member
Reply #6 on:
November 25, 2014, 11:42:04 AM »
Do both LEDs on that side fail to light? If so, there is probably a bad solder connection or a reversed LED. You can get more information by measuring the voltage on the LED terminals, but I'd suggest checking visually and re-flowing the LED joints even if they look good. You're going to need magnifier and a strong light!
Logged
YUL400
Jr. Member
Reply #7 on:
November 26, 2014, 04:07:26 AM »
I've resoldered both Leds on A end. After I've found one of them melted. They are very fragile components. I've ordered some from Digi-key. Will see with new Leds. I'll keep you updated.
Thanks.
Logged
YUL400
Jr. Member
Reply #8 on:
November 27, 2014, 03:59:23 AM »
Problem solved. New diode installed. Many thanks to you Digi-Key Corporation
www.digikey.ca
for your incredibly fast and professional service. The kind of service excellence that is only found in the aeronautical and / or medical sector. Thumbs up. Thanks to you too Mr Joppa for your help. It's now time for the first try.
Logged
Global Moderator
Hero Member
Reply #9 on:
November 30, 2014, 01:19:21 PM »
"Problem solved" - my favorite two words!
Congratulations, that one was a little tricky. Glad it's working now. :^)
Logged
Pages: [
Bottlehead Kits
Eros Tape
