3-Position Rotary Switch Has 10 Positions
Andrew Lee Rubinger · 2841
Offline Andrew Lee Rubinger
on: December 01, 2014, 12:47:32 PM
Hi, all:
In my first day of building the BeePre. :)
Noticed while mounting the hardware that my 3-position rotary switch actually has 10 "clicks" available to it.  It's stamped with "3E1" on the back; is this the correct part and if so, possible it's defective?
S,
ALR
Reply #1 on: December 01, 2014, 01:28:54 PM
There is a series of holes around the shaft of the switch that set the number of positions by inserting the tab of the tabbed washer into the corresponding hole. To fix it, turn the switch all the way counterclockwise, remove the switch from the chassis, move the tabbed washer to position 3, then reassemble.
Reply #2 on: December 01, 2014, 01:41:15 PM
Beautiful; thank you!
S,
ALR
