Do you need to prime the top plate before painting?
sbelyo · 2267
Offline sbelyo
on: December 10, 2014, 05:31:00 AM
I'm going to paint the top plate with Rustoleum Hammertone finish.  Do I need to prime the top plate before painting?
Reply #1 on: December 10, 2014, 11:25:17 AM
I scrub mine with hot soap and water, then a final wipe with alcohol just before I spray and it works well...John
Reply #2 on: December 10, 2014, 11:51:19 AM
Hammerite is one paint that specs no primer necessary. Don't know if the Rustoleum version specs the same or not, should say on the can. I've used both with good results. The only issue we have found is that it takes quite a while to harden, like a couple/three weeks. And if you try to accelerate the process by baking, the paint can come out so brittle that it cracks.
Offline sbelyo
Reply #3 on: December 10, 2014, 01:13:15 PM
Thanks Doc and John...
Good to know.  Guess I better paint this weekend if I want to build during the christmas holiday
