General Category
General Discussion
Anodized screws. Mainline.
Strikkflypilot
1686
Strikkflypilot
Sr. Member
Shellac fiddler
December 13, 2014, 01:42:16 AM
Hi.
From reading through the Mainline, I cannot see a reason the anodized screws(on the topside visible ones, not washers, nuts or that sort) I am planning to use should cause grounding issues.
Anyone thinking the contrary?
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
Paul Birkeland
Global Moderator
Hero Member
Re: Anodized screws. Mainline.
Reply #1 on:
December 13, 2014, 08:05:42 AM
You can double check with your meter to see if there is any issue with them. (Measure resistance between the #8 grounding screw and the center lugs of each 5-lug strip and the shield grounding solder tabs)
For mounting the terminal strips, I would put an extra lockwasher between each terminal strip and the chassis to aide in conduction.
Strikkflypilot
Sr. Member
Shellac fiddler
Reply #2 on:
December 13, 2014, 11:11:00 AM
Thanks.
Looking very much forward to this build.
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
General Category
General Discussion
