Transformer: Cosmetic damage during shipping?
shaun.meyer · 2141
Offline shaun.meyer
on: December 13, 2014, 06:40:46 AM
I was going over my parts a bit more closely now that I'm almost done with the finishing work on the case and noticed that my transformer has some cosmetic damage on two of its sides and I'm wondering if this is anything to be concerned about, or anything that might warrant a replacement as "damaged in shipment."
I've tried to capture some pictures of each side:
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2F0Zj3d4C.jpg&hash=0802748a24267cd05da5c74a14067c0f33088db7)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2FSJsREIo.jpg&hash=0bebaa8fd97b368c4a64ec705752d06c0975c7fa)
Shaun
Offline Strikkflypilot
  • Shellac fiddler
Reply #1 on: December 13, 2014, 07:16:22 AM
I believe that is the so called "goo".
A surface treatment to prevent rust that often has some smear.
Mine also has that, I didnt go through with sanding and painting, though, as it is hidden behind the 6080.
I guess fine sanding and rustoleum would do the trick?
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
Reply #2 on: December 13, 2014, 08:01:41 AM
That's the varnish that holds the transformer together.  You can paint over it if you like, and many builders will just blast the lamination stack with some black paint.
Offline shaun.meyer
Reply #3 on: December 13, 2014, 10:57:03 AM
You're right; I see it now that this is just some dried goop on the side. I sanded it off with some high grit sandpaper and painted the sides.
At first it really did look like the transformer had been dropped on its side!
Thanks for your advice!
