where to insert the quickie in my system?
bobster · 24743
Offline bobster
on: October 19, 2009, 05:25:37 PM
Okay - I can no longer ignore the rave over a quickie and I would like the capability to listen to headphones.  Given the system listed in my signature (when all is finished), where does a quickie as a headphone amp go?  Alternatively, does it make more sense to add the headphone output without adding the quickie?
I am a total know-nothing when it comes to how these beautiful pieces of equipment work. I just like the sound.  So please speak slowly and distinctly at a 5th grade level when responding.  No need to SHOUT however.  :-) (where are the smileys in this software?)
Appreciate any suggestions/input.
Thank you,
Bob Musson
Seduction (extended), Foreplay, Paramours, Klipsch Heresys, Orcas, Crack plus HD 600s
Lovin the Bottlehead sound in Maryland
Reply #1 on: October 19, 2009, 09:28:08 PM
I will take a crack at your question:
The Quickie is not the highest gain preamp on the planet, but the Foreplay III sure it.  If you used the FP-III to drive the Quickie, you would likely get better headphone performance than driving the Quickie directly (assuming a decent headphone match).
Adding the headphone output without the Quickie means redesigning the Foreplay into a SEX amp...
(Good luck on the Paramounts, taking plenty of time is a great idea!)
Offline bobster
Reply #2 on: October 22, 2009, 04:35:01 PM
So just directly connect the output from the FP directly to the input on the quickie with an interconnect?  That's all there is to it?
Bob Musson
Online Paul Joppa
Reply #3 on: October 22, 2009, 07:06:19 PM
That's another reason for having two outputs on teh Foreplay III  :^)
