Hummining/noise with the increase in volume
ajbar · 1862
Offline ajbar
on: December 21, 2014, 08:18:21 AM
Hey guys/gals,
I completed my bottlehead amp but noticed that after I turn the volume up past half way I start to hear a humming noise, which gets louder the higher I turn up the volume. This humming noise is present without any music playing and even if the rca cables are disconnected. I would appreciate any help with removing/minimizing this noise!
Thank you in advance!
-Andrew
Reply #1 on: December 21, 2014, 08:39:56 AM
Hello Andrew,
Which headphones are you using for this test?
With the level control up half way, is this a listenable range for your Crack with the particular set of headphones that you're using?
