Voltage check with Speedball
Jimb0 · 1946
Offline Jimb0
on: January 02, 2015, 11:35:31 AM
Hello guys,
I just recently upgrade my Crack with the Speedball and had a question about the voltages. Everything checks out fine except for terminal 7. The expected voltage is 100 but I'm getting around 85 volts. Is this too low? Also, I noticed the 4 LED's on the two small PC boards don't light up as bright as the other LED's. Is this a soldering issue?
Looking for your support. Thanks!
James
Offline Jimb0
Reply #1 on: January 02, 2015, 12:23:57 PM
N/m, the voltage went lower when I added the Tung Sol 5998. With the stock Jan 6080 WC it went back up to 100. I'm assuming this is normal when switching tubes. The only thing that I'm noticing right now is that the 4 LED's on the small pc boards are still dimly lit than the other LED's. Is this normal? Thanks
James
Offline borism
Reply #2 on: January 02, 2015, 12:32:14 PM
I also noticed a difference when I built my crack/speedball that some LEDs were brighter lit but I don't recall if it was the same pattern. Main thing for me was that everything measures well and sounds fine.
Boris
Reply #3 on: January 02, 2015, 12:33:04 PM
Big board LEDs draw way more current so they are brighter.
Offline Jimb0
Reply #4 on: January 02, 2015, 12:42:32 PM
Thank you Doc!
