input wire shielding
soundsgood · 1322
Offline soundsgood
on: January 03, 2015, 07:19:15 AM
this must be a dumb question because i have never seen it posted. would it be beneficial to run the braided input wire between the rca jacks and volume control within a copper tube with drain wire attached at volume control end, similar to tone  arm wiring?
Bob Zangri
Reply #1 on: January 03, 2015, 07:46:14 AM
You could do that if you end up with a noise issue.  Voltage from a phono cartridge in a tonearm is between 0.005-0.0001V, voltage from a typical source feeding a Crack would be 5V-0.3V, which makes it vastly less susceptible to noise intrusion.
The most beneficial precaution to take is to run the braided wires along the outside edge of the chassis plate, away from the red/black twisted pair of wires running to each tube socket.
