Any advantage to replacing PS resistors with chokes?
Tubejack · 19982
Offline braubeat
Reply #30 on: June 23, 2012, 04:23:48 AM
You test the capacitance between each wire and the core. Usually, you want the higher capacitance farther away from the plate of your tube. I think that's right.
Michael
Reply #31 on: June 23, 2012, 04:30:50 AM
Michael,
Thanks, so lowest capacitance (should be the dot) toward the plate/high voltage.
I will dot my Triad for the Eros today!
Edit:  the higher capacitance was on the left hand lead so the dot and wire on the right go to the second capacitor in the power supply, closer to the plate.
« Last Edit: November 02, 2012, 08:52:37 AM by Grainger49 »
Offline Noskipallwd
Reply #32 on: June 24, 2012, 11:25:47 AM
Thanks for the info, Triad's docs don't mention that at all. I got the crack right by chance, need to check the Eros. I'm a little burnt-out, just got home. We had to evacuate all of our patients at the hospital due to the Waldo canyon wildfire. I got out just before they closed the highway. They believe the fire was arson, just don't understand people like that.
Cheers,
Shawn
Shawn Prigmore
Offline Dr. Toobz
Reply #33 on: June 25, 2012, 12:09:31 PM
OK, here's a question for those of you who have already installed the Triad choke: where did you find standoffs with a sufficient diameter to connect to the bolts holding down the power transformer? Nothing I have on hand seems to be the correct gauge.
Offline Mr. Davis
Reply #34 on: June 25, 2012, 01:31:08 PM
Mouser.com
6-32 screw  http://www.mouser.com/Search/ProductDetail.aspx?R=8420virtualkey53400000virtualkey534-8420
8-32 screw  http://www.mouser.com/ProductDetail/Keystone-Electronics/8433/?qs=1eFRaVyeUDVBTujGLm7s9OVyuZjjX5tpZdrvxESCFCw%3d
« Last Edit: June 25, 2012, 01:37:47 PM by Mr. Davis »
Perry Davis
Offline Dr. Toobz
Reply #35 on: June 25, 2012, 02:12:37 PM
Thanks! The Crack manual states that the screws holding down the power transformer are #8-32, so I'll go with the #8 standoffs listed at Mouser. Too bad these aren't available at Home Depot or something - it stinks to pay so much shipping for such little parcels.
Reply #36 on: June 25, 2012, 02:28:07 PM
Find the manufacturer's part number and order it from Digi-Key.  They offer a first class mail option for just a few dollars.
« Last Edit: November 02, 2012, 08:53:42 AM by Grainger49 »
Offline Dr. Toobz
Reply #37 on: June 25, 2012, 02:43:05 PM
Great idea - I completely forgot about DigiKey! I've ordered things from them in the past via USPS.
Here's the link for the same part at DigiKey: http://www.digikey.com/product-search/en?x=0&y=0&lang=en&site=us&KeyWords=keystone+8433
Offline Dr. Toobz
Reply #38 on: June 25, 2012, 05:43:26 PM
Despite not yet having the standoffs to mount the choke, I did install it in place of the first 270 ohm resistor, and simply set it behind the amp until the hardware arrives. Now, I'll admit to not really knowing how this is possible, but the choke definitely does improve the amp. Is it a gigantic improvement? Not really, but it is definitely noticeable.
The first thing I noticed is that bass notes are a bit deeper and more solid, yet not as forward in the soundstage. I can actually hear a bass note and its harmonics (or the strings vibrating, etc) rather than just a low tone or rumble, which is perhaps the biggest change. The bass actually is detailed and tuneful. Secondly, the soundstage has opened up a bit. Perhaps as a result, I noticed that things are a bit better balanced, in that the amp paradoxically seems less bright while revealing more tiny details in some songs (background noises, fingernails on strings, etc). Loud transients are now less startling and very smooth, almost effortless. The sound is even more natural than before. Finally, the leading edge of transients seems to be ever so slightly better defined, again without making the amp sound sharp or treble-heavy.
In short, a good upgrade, and likely my last! When an amp is so good that you forget you are wearing headphones, I don't know how much better things could get. This is definitely a "last 1%" type of upgrade, and to be honest, I didn't expect any difference with active plate loads following the power supply. I can only surmise that the choke is making their jobs easier....
Offline Mr. Davis
Reply #39 on: June 25, 2012, 06:13:36 PM
I've been using a choke at the second 270 ohm resistor for over a year now.  Still sounding great.
Actually, it sounds even better since I finished my Buffalo 3 Dac a few weeks ago.  I love the way my Crack sounds.  :)
Perry Davis
