LEDs not lighting Help Please (solved) New C4S Board
thdewitt · 6516
Offline thdewitt
on: January 16, 2015, 07:37:00 AM
OK, so I finally got around to finishing my Bee Pre.  I built pretty much all of the kits.  This one was definitely the most involved.  Everything on the resistance seems to check out fine but the voltages do not.  I am not getting the bottom two LED's to light on the right side CS4.   :'(
(https://dl.dropboxusercontent.com/u/38833957/2015-01-15%2020.37.35.jpg)
I have looked through the instructions and compared to the other side and can't locate the problem.  Any ideas on what I can test to narrow the problem down.
Tom
« Last Edit: January 27, 2015, 01:45:53 PM by thdewitt »
Eros Telefunken EF806S and Telefunken E88CC
BeePre JJ 300B
Paramount 1.1 EH 300B
Stereomour JJ 2a3-40 and Mullard CV4024
Crack Tung Sol 5998  Mullard CV 4003
Thorens TD 160 Super (Vinyl Nirvana)
Blumenstein Orca Deluxe/Dungenus Sub
Blumenstein Mako Floorstanders Chocolate Bamboo
Reply #1 on: January 16, 2015, 07:50:55 AM
Post the voltages that are off.  Also post the expected voltage.
Offline thdewitt
Reply #2 on: January 19, 2015, 11:18:38 AM
OK, sorry it took so long I have been out for the weekend.  So I am going to just post the voltages that are off since there are so many.
terminal        Correct
10   178.7     186
11  182.5      146
16   0            5
17   181        90-110
22   205        213
25   205        213
29  8.1          6.8
30  8.2          6.8
31  16.3         13.6
34  12.8         13.6
40  209          213
b2  181          90-110
d3  1.9           3.5-4.5
d7   182         147
d9   180         147
Any help would be appreciated.  There is something wrong with the power supply on the right side just can't seem to see it.
Tom
BeePre JJ 300B
Reply #3 on: January 19, 2015, 01:52:18 PM
The 300B on that side isn't drawing any filament current, as can be seen by having 0V on terminal 16.  If you have 10V or so at POS OUT on that side, then you should have 10V going into the 300B, passing through the 300B filament, then traveling through the paralleled 8 Ohm resistors.
This could be an issue of an improperly oriented 4 pin socket, or no voltage at POS out.  (Go ahead and measure it)
Offline thdewitt
Reply #4 on: January 19, 2015, 03:10:25 PM
I am getting zero at the positive out.
Tom
BeePre JJ 300B
Reply #5 on: January 19, 2015, 04:25:26 PM
How about at positive in?
Offline thdewitt
Reply #6 on: January 19, 2015, 04:42:01 PM
OK, I found a broken wire on the positive in.  I replaced that as somehow it had a cut.  Anyway.  The voltages have changed but still no light on the diodes.  Here are the voltages out of whack now.
Terminal    Reading   Correct
 10           173          186
15            175          186
17            127          90-100
22            201          213
25            202          213
40            202          213
43            202          213
46            202          213
b2            132          90-110
d3            7.0           3.5-4.5
BeePre JJ 300B
Reply #7 on: January 19, 2015, 04:45:47 PM
What voltage do you have at POS OUT now?  It looks like that 300B still isn't conducting all the way.
Offline thdewitt
Reply #8 on: January 19, 2015, 04:47:18 PM
9.79 Volts.
BeePre JJ 300B
Reply #9 on: January 19, 2015, 05:21:45 PM
Alright, that's spot on.  Can I get the IA, OA, and OB voltages on the offending channel?
Offline thdewitt
Reply #10 on: January 19, 2015, 05:28:16 PM
IA 174.7
OA 130.4
OB 121.8
Thanks so much Tom
BeePre JJ 300B
Reply #11 on: January 19, 2015, 05:47:55 PM
Can you switch both the EL84 and the 300B between channels (do them both at once).
Your 300B isn't drawing current, and the shunt regulator is also not regulating properly.
Offline thdewitt
Reply #12 on: January 19, 2015, 05:54:18 PM
Pretty much stayed the same
IA 174
OA 127.1
OB 121.8
Tom
BeePre JJ 300B
Offline thdewitt
Reply #13 on: January 19, 2015, 05:55:19 PM
I wrote the OB wrong.  IT was 119.5
BeePre JJ 300B
Reply #14 on: January 20, 2015, 07:11:37 AM
The next thing I would do is to recheck the IA, OA, and OB voltages with no EL84 plugged into that channel.
