My Crack build w/ manual queries
denti alligator · 8729
Reply #15 on: January 22, 2015, 11:00:24 AM
They are. I'll double check the wiring in about an hour when I get home. What do the high voltages at T5, T9, A1,
B4, B6 suggest?
They are all related to the same problem, that one half of the 12AU7 isn't glowing.
If you believe it to be the LED, you can connect a wire between A3 and A8.
Offline denti alligator
Reply #16 on: January 22, 2015, 11:09:29 AM
I don't know anything ... I'm at your mercy :)
All I know is what I've posted. Is it possible the LED isn't working? is broken? What will wiring A3 to A8 do?
- Sam
Reply #17 on: January 22, 2015, 11:22:27 AM
Wired A3 to A8. Same problem.
What should I try next?
- Sam
Reply #18 on: January 22, 2015, 11:24:06 AM
I'm guessing one or both LED's light with the jumper in?
Reply #19 on: January 22, 2015, 11:28:13 AM
Hadn't looked at the underside. Only half the tube glows (same half). Both LEDs light up now. Haven't re-checked voltages.
- Sam
Reply #20 on: January 22, 2015, 11:43:52 AM
What should I try next? Should I remove the wire between A3 and A8 to start with, now that we've determined the LED is fine?
EDIT: Just double-checked all the wiring. Unless I'm overlooking something (possible, of course), I think everything is where it should be.
« Last Edit: January 22, 2015, 12:05:06 PM by denti alligator »
- Sam
Reply #21 on: January 22, 2015, 01:03:14 PM
What are the chances the tube is no good?
- Sam
Reply #22 on: January 22, 2015, 01:27:55 PM
Why don't you measure the resistance across each half of the heater?
Reply #23 on: January 22, 2015, 01:31:48 PM
Can you tell me how to do this.
- Sam
Reply #24 on: January 22, 2015, 02:04:25 PM
Set your meter to Ohms, put the black probe on pin 9 of the 12AU7 out of the socket, then measure resistance between 9 and 4, then 9 and 5.
Offline Jimb0
Reply #25 on: January 22, 2015, 02:07:02 PM
I reflowed A5 and A6. Still not working. Any other ideas?
Judging by the picture it looks like you didn't put enough solder on some of those terminals but it could just be the way I'm seeing it from the picture. I don't think it would hurt to add extra solder.
Reply #26 on: January 22, 2015, 05:28:41 PM
You mean the tube itself? pin 4 is 4.38k; pin 5 is 7.5
(Seems like pin 4 is fluctuating. Now I'm getting in the 600 range. Yeah, every time I try it I get a new number, ranging from 300 to 47k. Meter works fine, as far as I can tell, measuring other things.)
The solder on the terminals is about how much I've used on my past three successful BH builds.
« Last Edit: January 23, 2015, 05:49:10 AM by denti alligator »
- Sam
Reply #27 on: January 23, 2015, 06:18:48 AM
Does this mean I have a bad tube?
- Sam
Reply #28 on: January 23, 2015, 07:05:24 AM
Could be bad, but try cleaning pin 4 and measuring one more time.
Reply #29 on: January 23, 2015, 07:11:14 AM
Used deoxit. Still measuring all over the place.
EDIT: Guitar shop downtown has some Electro-Harmonix 12AU7s. Those any good? I might pick one up to hold me over till a replacement comes if it's really this tube that's bad.
« Last Edit: January 23, 2015, 07:33:28 AM by denti alligator »
- Sam
