a couple random technical questions
aragorn723 · 4518
Offline aragorn723
on: January 24, 2015, 07:23:42 AM
Hi,
It has been a while since I built the Quickie, but don't remember seeing anything on ESD.  Is that because the components aren't particularly sensitive?  Also, is the Quickie phase-inverting?
Dave
Reply #1 on: January 24, 2015, 07:29:30 AM
The Quickie is polarity inverting (all Bottlehead preamps ever produced invert polarity, except the Submissive).  Resistors, capacitors, batteries, and tubes aren't ESD sensitive.
Offline aragorn723
Reply #2 on: January 24, 2015, 07:43:39 AM
So does that mean to get the best sound the positive and negative should be switched?  (hook up + amp to - speaker and vice versa).  Thanks,
Dave
Reply #3 on: January 24, 2015, 07:49:52 AM
Does your amplifier also invert polarity?
You can listen to it both ways.
Offline aragorn723
Reply #4 on: January 24, 2015, 08:09:04 AM
Paul,
The amp doesn't invert polarity..  It's kinda fun to see that there are still things to play with on the Quickie!  Just changed the coupling caps to K75-10s, and got some black gates to replace the 150uf caps.  So much to tweak, so little time  ::)
Dave
Reply #5 on: January 24, 2015, 08:36:15 AM
This is just one place where a polarity flip can happen. It can happen in every other piece of gear and at each driver in your speakers. All that matters is the polarity of the drivers.
Reply #6 on: January 24, 2015, 02:56:40 PM
So does that mean to get the best sound the positive and negative should be switched?  .  .  .
The worst thing about keeping absolute phase in your system is that there is no standard on recordings.  Some invert absolute phase and some don't.
Reply #7 on: January 24, 2015, 06:17:24 PM
... and many multitrack recordings are different for different instruments ...
Offline aragorn723
Reply #8 on: January 25, 2015, 02:27:48 AM
i tend to like the sound of woofers/subwoofers out of phase.  It isn't as loud as in phase, but has a tighter sound.  What would happen to tweeter sound?
Dave
