100K Goldpoint Potentiometer
thdewitt · 3706
Offline thdewitt
on: January 27, 2015, 06:39:21 PM
Hello,  just checking.  I have a 100k Goldpoint Custom Potentiometer.  I can just drop this in to the BeePre correct.  I read a previous post that both of Volume and Balance pots are 100K and that together they are 50K.  Does that make sense.  Want to drop this in tomorrow if that is correct.
Tom
Eros Telefunken EF806S and Telefunken E88CC
BeePre JJ 300B
Paramount 1.1 EH 300B
Stereomour JJ 2a3-40 and Mullard CV4024
Crack Tung Sol 5998  Mullard CV 4003
Thorens TD 160 Super (Vinyl Nirvana)
Blumenstein Orca Deluxe/Dungenus Sub
Blumenstein Mako Floorstanders Chocolate Bamboo
Reply #1 on: January 28, 2015, 06:20:29 PM
You could replace the 100K level control with the Goldpoint level control.  If you opt for the BeeQuiet upgrade, the Goldpoint will need to be removed.
Offline thdewitt
Reply #2 on: January 29, 2015, 07:03:42 AM
Thanks, I was just going to put in a gold point volume control and selector switch so that I didn't lose the balance control.  My room is set up in such a way that the balance is very helpful.
Tom
BeePre JJ 300B
Offline thdewitt
Reply #3 on: January 29, 2015, 10:36:04 AM
Installed the potentiometer and the Selector Switch.  The BeePre is very sensitive and at higher volume you can here the potentiometer as it moves from setting to setting.
Tom
BeePre JJ 300B
