Resistance check issues [solved]
Kaalpurush · 1560
Offline Kaalpurush
on: January 31, 2015, 08:22:28 PM
Just finished assembling the Crack, the whole process went very smoothly even for a novice like me. While doing the resistance check a few unusual readings were observed. Just for a background I also did the startup voltage mod for headphone jack.
T4 - *8.3Mohms
T5 - *7.2Mohms
T6 - 1.7ohms
T10 - 1.8ohms
T13 - 278Kohms
In case of T13 resistance reads 12Mohms first then slowly starts to climb down to 278Kohms, it takes almost 9-10 minutes for the whole climbing down process unlike what the manual says. I double checked all soldering connections and capacitor directions. Is it safe to move on to voltage check?
Thanks in advance!
« Last Edit: February 03, 2015, 06:22:42 AM by Caucasian Blackplate »
Reply #1 on: February 01, 2015, 09:21:52 AM
You can move ahead to the voltage checks.  T6 and T10 are off because of the modification, and the other terminals are OK.
Offline Kaalpurush
Reply #2 on: February 03, 2015, 04:58:09 AM
Thanks again, everything works as expected. It was an awesome experience and yeah it sounds great with my HD-650.
