Some questions at starting the soldering job.
Strikkflypilot · 3796
Offline Strikkflypilot
  • Shellac fiddler
on: February 01, 2015, 05:39:10 PM
Hi.
I was just wondering, when soldering the grounds to the transformers, to make it clean , I have twisted the three cables going from the ground screw and used shrink tubing, letting one by one leave the twist as the ground buss passed Ot(c) , PT, an finally one left for OT(a).  Sounds ok?
And the wiring of the PT5, is it ok to solder the drain wire to the ground screw instead of the E of the IEC?
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
Reply #1 on: February 01, 2015, 06:12:13 PM
That should be ok.
Having the drain wire connect to the "E" lug will keep that piece of STP in a good position.  If all the connections are off to its left, it may work its way left, which isn't very desirable.
  • Shellac fiddler
Reply #2 on: February 01, 2015, 07:10:39 PM
Thanks PB
So I understand it is a mechanical issue.
I have another zip tie down mount for that.
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
