Quickie + PJCCS - lost bass
danielehn · 9840
Offline danielehn
on: February 04, 2015, 09:02:04 AM
Hi,
I've had my quickie for a while now and it's great.
However after not using it for a longer period it seems to have lost the low frequency bass.
Everything else is fine. The feeling is that of having a home cinema receiver where you can select at which frequency the sub-woofer is
to take over.
I tried connecting my subwoofer to the outputs of the quickie just to see if it would perform deeper bass, but it also seemed not producing low frequency bass.
I also tried another power amplifier that used to sound a bit overblown and used to produce to much bass. This power amp were also not producing the deep
bass that I used to love so much.
Is there something that might have broken inside my quickie that could account for this ?
Any help is much appreciated
Offline galyons
  • Geary Lyons
Reply #1 on: February 04, 2015, 09:34:37 AM
Since sat for awhile, did you put in fresh batteries?
Cheers,
Geary
Offline danielehn
Reply #2 on: February 04, 2015, 10:00:24 AM
Hi, Yes, bought new ones. Can hear a little bit of difference when the D-Cells are completely new but it's not what it used to be.
What is the normal voltage lvl at which the D-Cells needs to be replaced ?
(When mine hits 1.35 I can clearly notice that the sound quality have deteriorated)
Reply #3 on: February 04, 2015, 02:42:25 PM
The broadest specification I've seen says the tube wants at least 1.0 volts. I think the tube designers expect it to work down to 1.125v.
As the batteries run down, it becomes more important that the D-cell orientation is correct - for version 1.0, see the sticky about the error in the manual. This is fixed in the current Quickie version.
Offline danielehn
Reply #4 on: February 05, 2015, 08:43:45 AM
I'll give that a try after buying a few new batteries :)
Tried with the old ones but they sound awful at 1.35V with loss of clarity and punch.
Is all of the quickie 1.0 manuals (CD's) incorrect ?
Reply #5 on: February 05, 2015, 08:44:54 AM
The old Quickie 1.0 does need to have the D-cells flipped.  The Quickie 1.1 does not.  Rather than redo the 1.0 manual with revised wiring, we made other changes to the kit and addressed that issue with the 1.1 revision.
Offline danielehn
Reply #6 on: February 09, 2015, 03:56:47 AM
I'll check if I flipped the holders before. I don't remember.
The sound however is more or less exactly the same no matter how the batteries are placed.
(Lacking bass)
Offline danielehn
Reply #7 on: March 30, 2015, 06:31:52 AM
Have tested with different sources and when connecting a volume pot and a CD player directly to the power amplifier the sound is much more aggressive and there are more bass. Have also noticed that the sound stage is to wide and lacks focus using the quickie. Since this started after having it in storage for a while I wonder if some thing has come loose and it's not producing the voltage it's supposed to.
Offline Zimmer64
    • Blog
Reply #8 on: March 30, 2015, 09:04:05 AM
Is there enough juice in the 9v battaries left as well?
Offline danielehn
Reply #9 on: March 30, 2015, 09:06:20 AM
I've probably gone thru 3 sets of fresh batteries since I started troubleshooting.
Don't really think it's battery related any more.
It's like voices aren't distinctly in the middle of the room, but smeared out a bit as well..
« Last Edit: March 30, 2015, 10:16:13 AM by danielehn »
Reply #10 on: March 30, 2015, 02:49:02 PM
A voltage check would be a good starting point for diagnosis.
Offline danielehn
Reply #11 on: April 01, 2015, 07:11:35 AM
Voltages are about 34v & 1,6v( pjccs manual measurement points ). think that isn't far off ? since the 9v batteries are at 34v and the D cells are about 1.4v.
Tested with a tone generator and an 80hz tone sounds like a ticking sound . (clipping)
Higher frequencies sounds better.
« Last Edit: April 01, 2015, 07:13:23 AM by danielehn »
Reply #12 on: April 01, 2015, 10:05:27 AM
For which points?  34V is OK for IA/IB, for for OA/OB or tube pins 4/6, that's a tremendous problem.
Offline danielehn
Reply #13 on: April 01, 2015, 07:46:36 PM
IA,IB = 34v
Tube Pin 6 = 1,6v
Offline danielehn
Reply #14 on: April 02, 2015, 06:19:29 AM
I took a 100k pot and connected it to a couple of rca connectors (no quickie involved just for testing). When running this way with my power amplifier and CD player. Even at the lowest level for the pot I got a super high volume. And if I would have tried to raise the volume I would have blown my speakers. Is this normal?
« Last Edit: April 02, 2015, 06:29:57 AM by danielehn »
