Testing LEDs?
audiomaniac · 1842
Offline audiomaniac
  • No hill too steep, no ditch too deep!
on: February 08, 2015, 11:13:25 AM
Is there a way to test an LED while building the Crack? When I was soldering the second LED to A8, it shifted a little and some solder flowed right up to the edge. I hope it's not damaged and was hoping I could confirm this somehow before proceeding.
John
Crack
Reply #1 on: February 08, 2015, 11:22:33 AM
Some meters can light them up on the diode check setting with the probes oriented in the correct direction.  You can try this by using your meter on the diode that isn't suspect.
Offline audiomaniac
Reply #2 on: February 08, 2015, 11:30:26 AM
Sure enough! It lights, in fact they both do! Thanks very much!!
John
Crack
