noob ? on cap rolling
pro_crip · 3348
Offline pro_crip
on: May 21, 2010, 12:05:47 PM
Hi all,
       When you start swapping caps, which ones should I start with and how close do I have to match the specs of the stock cap? I went looking through pcx and my head started swimming. Thanks a bunch
Rich
Richard J Feldman
Tune down, smoke up
Reply #1 on: May 21, 2010, 12:07:11 PM
Are you speaking of coupling caps or power supply caps?  I agree on the variety, my head swims every time I look for coupling caps there.
Offline pro_crip
Reply #2 on: May 28, 2010, 01:59:14 PM
It turned out I was confused by the concept of bypassing caps. I'll do some poking around and see what I find. Thanks, especially for that list.
Rich
Richard J Feldman
Tune down, smoke up
Offline pro_crip
Reply #3 on: May 28, 2010, 03:45:33 PM
I did find a cap comparo out there http://www.ecp.cc/cap-notes.htm. He's got more links to other comparos. Sorry if this info has been repeated. I found some 150uf / 350v blackgates at parts connexion and I was wondering if those can be swapped in for the panasonics in the power supplies? Btw, I've got crack (speedball on pre-order), extended FPiii, eros and paramount 300b's.
« Last Edit: May 28, 2010, 04:45:09 PM by pro_crip »
Richard J Feldman
Tune down, smoke up
