Help with Speedball Mod [Solved]
TRTim · 1994
Offline TRTim
on: February 10, 2015, 05:46:31 AM
I may have fried the transistor on the large Speedball board. Originally, I installed the LEDs backwards on the left side of the board. I have corrected that issue but the voltages I am getting are off. They are:
Term
1   179
2   180
3   0
4   180
5   77.9
6   0
7   172
8   0
9   112
10  0
11  0
12  0
13  181
15  199
20  0
21  216
I completed the Crack headphone amp and ran in the amp for about 20 hours before adding the boards, so I think the base wiring is OK. Can you please help.
Tim
« Last Edit: February 10, 2015, 06:23:44 PM by Caucasian Blackplate »
Reply #1 on: February 10, 2015, 07:10:40 AM
179V on terminal 1 would indicate:
The 2N2907 not being installed (did you swap it with a 2N2222 on the big board?)
The R1 resistor being swapped with an R1 resistor on the big board
The center leg of the MJE-350 needing extra heat to solder properly
Other issues present before Speedball (shouldn't be the case in your repair)
Offline TRTim
Reply #2 on: February 10, 2015, 09:52:55 AM
After a quick test of the resistors R-1 with my ohm meter, I had indeed put the wrong one on board "A". I swapped them back and all of the voltages went to their correct value. I am now playing Bach's solos for unaccompanied cello by YoYo Ma and life is good.
Tim
Offline Nathan
Reply #3 on: February 10, 2015, 12:48:51 PM
Tim
Good reason to measure each resistor and check each part more than once before committing to installation.
Crack/Speedball, SEX 2.1/C4S, Bryston BHA-1
Sennheiser HD600/Cardas cable, Beyerdynamic T1 2nd Gen, Hifimam HE560/Hifiman balanced cable
