galyons · 2901
Haha! Sorry, it was unclear and has been a confusion before. Yes, from a stability standpoint the 100uF could be a lower capacitance and the 2200uF could be a larger capacitance. Below about 50uF, the 6922 cathode bypass will have an audible effect on bass extension and I do not recommend it.I think 160v is close to an optimum rating for the 100uF if it is electrolytic, and the 2200uF should have a low voltage rating, like 4 or 6.3 volts. Higher voltage ratings should work; they will eventually lose their ability to withstand the full rated voltage but should continue to perform well at lower voltages as long as it's enough to maintain the chemistry. Sorry I don't understand that low-voltage chemistry very well yet.
Pinging the common genius again on lowering the capacitance of the cathode bypass cap. Would 62uF be enough above 50uF to avoid stability issues and/or loss of bass extension? Cheers,Geary
