Selector Switch Replacement
ptlud · 6041
Offline ptlud
on: February 13, 2015, 08:29:12 AM
My Stereomour selector switch has developed an anoying pop.  I am looking for recommendations for a good replacement/upgrade.  Does the switch need to be shorting or non-shorting?
By the way, the amp sounds great with 45 tubes.
Your assistance would be greatly appreciated.
Paul
« Last Edit: February 13, 2015, 09:15:06 AM by ptlud »
Paul
Stereomour 2A3
Modded Toshiba 3950 DVD Player + Schiit Uber Bifrost DAC
JVC A40 Turntable with AT95e + Schiit Mani Preamp
Klipsch KLF-20
Offline Natural Sound
Reply #1 on: February 13, 2015, 10:07:26 AM
Hi Paul, I used a Goldpoint 4P-3T-1D in my Foreplay III. The input scheme is similar to the Stereomour. They aren't cheap at $72 but work well last a long time.
http://www.goldpt.com/selector.html
Offline ptlud
Reply #2 on: February 13, 2015, 10:12:21 AM
Thanks for the suggestion.  Is the switch shorting or non-shorting?
Paul
Stereomour 2A3
Klipsch KLF-20
Offline galyons
  • Geary Lyons
Reply #3 on: February 13, 2015, 10:15:52 AM
There are several good high end switches.  Elna, Goldpoint, & Grayhill have all been used extensively in quality audio. I have Grayhill's in all of my BH kit that switches.  Just be sure to get a switch that maintains the switching of both the signal and the ground. That is the superior topology and the way that the Stereomour is wired with the stock switch.
Cheers,
Geary
Reply #4 on: February 13, 2015, 10:24:06 AM
I'm not 100% sure but I think its shorting.
Reply #5 on: February 13, 2015, 11:33:42 AM
Cheers,
Geary
Do you remember what Grayhill models you used?
Offline galyons
  • Geary Lyons
Reply #6 on: February 13, 2015, 11:52:22 AM
It is:
GRAYHILL 44HS30-01-4-03N MIL SPEC
Number of Positions: 3
Number of Decks: 1
Number of Poles per Deck: 4
Current Rating:      1 A
Voltage Rating:      115 VAC, 28 VDC
Index Angle:          30 deg
Contact Style:        Non-Shorting
Termination Style: Solder Lug
Mounting Type:     Panel
Contact Plating:     Silver
Actuator:      Flat
http://www.mouser.com/ProductDetail/Grayhill/44HS30-01-4-03N/?qs=ls7QRyWmRk4H00XMNGdLbA==
Cheers,
Geary
