Quickie build resistance readings
mkane · 6581
Offline mkane
on: February 21, 2015, 08:23:15 PM
   On the A side. Rotary switch 8&9 I'm getting 18.5
                          Terminal strip #4    "       "       20+  Both should be 1.07
    B side is good. Re soldering doesn't seem to do it.
« Last Edit: February 22, 2015, 09:02:05 AM by mkane »
Reply #1 on: February 22, 2015, 02:39:55 PM
Did you, by chance, swap the 1.07K resistors with the 475K resistors?  (Check the writing on the parts)
Offline mkane
Reply #2 on: February 22, 2015, 04:41:42 PM
  Ashamed to post a pic of this 'birds nest' but here it is. B side tests fine. And I thought this was going to be a piece of cake. I believe the resisters are in there correct spots.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi285.photobucket.com%2Falbums%2Fll58%2FMKane63t%2F001_zpszbm9ylsg.jpg&hash=0dfa25d377d513bcd05c325a9a623edaa8e1c35e)
Reply #3 on: February 22, 2015, 04:55:15 PM
It's hard to say, you can easily measure the resistors across the output jacks to double check.
Offline mkane
Reply #4 on: February 22, 2015, 05:00:33 PM
  Are all 4 of those brn resistors the same?  Better pic. So just stick the leads of the meter across  the out jacks.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi285.photobucket.com%2Falbums%2Fll58%2FMKane63t%2F003_zpsoqtqj46x.jpg&hash=c614cc718c76f1b26d4e54b905601365079ec9ec)
Reply #5 on: February 22, 2015, 05:04:38 PM
No they are not. PBs suggestion to measure them is a very good one.
Offline mkane
Reply #6 on: February 22, 2015, 05:09:19 PM
   I had black probe on ground buss and red on b out  measured .458. A out measured 1.069
Offline mkane
Reply #7 on: February 22, 2015, 05:14:18 PM
  The 2 resistors on the left side are backwards. I hope thats the problem. I need to get in the car and head to the airport to pick up my wife. I thank you both very much and I'll be in touch in the morning. Enjoy your evening. One more thing. How do I incorporate this with my Steromour?
Offline mkane
Reply #8 on: February 23, 2015, 06:52:55 AM
  Bingo and were done. Everything reads just right. Now to figure out how to incorporate this with the Stereomour. I'm thinking Phone pre to outputs, Quickie inputs to Stereomour in?  Ive have it running bit sound only in red side. I'mm measure again.
« Last Edit: February 23, 2015, 07:19:34 AM by mkane »
Offline mkane
Reply #9 on: February 23, 2015, 07:33:35 AM
  Resistance/voltage checks are good. I've reversed tubes also.
Offline mkane
Reply #10 on: February 23, 2015, 07:43:18 AM
  And when I pull the black side interconnect there's a loud buzz
Reply #11 on: February 23, 2015, 08:11:59 AM
The phono pre output would go the Quickie input. Quickie output goes to Stereomour input.
Offline mkane
Reply #12 on: February 23, 2015, 08:56:12 AM
  Just getting this loud buzz
Offline mkane
Reply #13 on: February 23, 2015, 09:08:39 AM
  I had sound from one side once, but now theres none. It's more of a hum
« Last Edit: February 23, 2015, 09:21:56 AM by mkane »
Offline mkane
Reply #14 on: February 23, 2015, 10:32:17 AM
  Well, she's working now and sounds fantastic. It's going to take a few days of critical listening to see what this has brought to the system. We have 3 turntables in rotation but I think I'll stick to the VPI.  The amps are pushin Cornwalls. Playing a bit of Joe Bonamassa.
Edit. I'm running the Stereomour's volume control wide open and fine tuning with the quickie's.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi285.photobucket.com%2Falbums%2Fll58%2FMKane63t%2F015_zps7tlatyon.jpg&hash=2e73648bfce924fb64700ce609e7e51364c23561)
« Last Edit: February 23, 2015, 10:34:41 AM by mkane »
