Seductor input impedance
xcortes · 8479
Offline xcortes
on: February 22, 2015, 04:10:35 PM
Back to my project of using multiple Seductors in series. Question, can the input resistor (hence impedance) of the Seductor be increased? What would be the limit?
Xavier Cortes
Reply #1 on: February 22, 2015, 04:24:10 PM
How high do you want to go?  At some point, if you go high enough, some voltage will develop across the grid leak resistor setting the input impedance, and that is to be avoided.  If you can scrounge up a 10M pot, you could roll through 10-20 6AU7's and adjust the grid leak till you see -0.1V across the resistor, then have a look at how consistent and how high those values are.
Offline xcortes
Reply #2 on: February 22, 2015, 04:40:18 PM
I'm thinking eight in series per channel so the inputs would be in parallel. Ideally I would love the preamp to see 100k but that would mean 1.5 meg which seems like a lot to me?
Xavier Cortes
Reply #3 on: February 22, 2015, 04:54:49 PM
1.0 Meg is a common spec for these small signal tubes. The 6AU6 specification does not say, but that should be OK. 67K seems a small price to pay.
Reply #4 on: February 22, 2015, 04:56:52 PM
It's sort of a lot, but when they are all paralleled together, you have a nice low impedance for that occasional 6AU6 that wants to let some spare electrons through.
Offline xcortes
Reply #5 on: February 22, 2015, 05:15:44 PM
Perfect!
Xavier Cortes
