Shorted LED, but amp still works
StudioDweller · 2249
Offline StudioDweller
on: February 23, 2015, 08:13:17 PM
I completed a very enjoyable build and all resistance values were good and initially, all voltage checks were good with the exception of the following:
B1 149 (90 expected)
B3 149 (90)
A6 149 (90)
If my memory serves, both LEDs were not illuminated during the initial power up. During subsequent checks, I accidentally shorted the A8 LED to A9 and I believe the ground probe of my meter shorted to one of the adjacent terminals when I removed it producing a spark. After both of those things happened, I also had higher than expected voltages at terminals 1 and 7 - both were 149.
After reading this thread about the LEDs I reflowed the LED connections and a suggestion was also made to connect a wire between A3 and A8 which I did. After adding that wire all voltages measure fine now and the only remaining issue is the A8 LED not lighting. However, the amp seems to work. I plan on giving it a more extensive test later, but if the A8 LED is not lit and/or is blown what effect would that have on the amp? -Thanks
« Last Edit: February 23, 2015, 08:59:03 PM by StudioDweller »
Reply #1 on: February 24, 2015, 07:58:15 AM
If you have an issue with one half of the 12AU7, but not the other, having the bias for each side done with two LED's can be a little more visually informative.
Channel separation with the single LED shouldn't be compromised, as the dynamic impedance is very low.
Reply #2 on: February 24, 2015, 08:09:42 AM
Thank you! Everything checks out and sounds great, but I will replace the LED so it's as it should be. Next time I will be bit more steady with my test probe!
