Quickie Upgrade [Solved]
mkane · 8664
Offline mkane
on: February 25, 2015, 04:06:00 AM
 Voltage readings A5  275mv
                            A6  2.8v
                            B5  1.9v
                            B6  27v  Something's amiss with A side. Seems like it should be so easy.??????????
« Last Edit: February 26, 2015, 11:00:32 AM by Caucasian Blackplate »
Reply #1 on: February 25, 2015, 05:41:51 AM
Is this with the PJ CCS?
Offline mkane
Reply #2 on: February 25, 2015, 06:00:08 AM
It is and I think I've found the problem.White wire was connected to U2 when it's suppose to go to A2. Volts on A side are a bit high but it's better than a few mv.  No sound from A side
« Last Edit: February 25, 2015, 06:05:36 AM by mkane »
Offline mkane
Reply #3 on: February 25, 2015, 06:24:46 AM
A6 /36.9A
B6/36V
A5/2.9V
B5/1.9v
 There is just a hum, no sound?
« Last Edit: February 25, 2015, 06:37:58 AM by mkane »
Offline mkane
Reply #4 on: February 25, 2015, 06:38:29 AM
  Those #6 pins should read 19-21V
Offline mkane
Reply #5 on: February 25, 2015, 06:52:20 AM
 These 4.02 resistors, in my build the yellow stripe is @ the bottom. The pic looks as though the stripe is at the top. Does this matter?
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi285.photobucket.com%2Falbums%2Fll58%2FMKane63t%2F001_zpss5qnzmz1.jpg&hash=6fcfeb5ca41e0740be153e6eae89e6056ec64a30)
Offline kgoss
Reply #6 on: February 25, 2015, 08:04:08 AM
Resistors are not directional. As long as you install yhe right one orientation does not matter
Ken Goss
Offline mkane
Reply #7 on: February 25, 2015, 10:08:34 AM
 Thanks but still no love
Reply #8 on: February 25, 2015, 10:18:45 AM
Post photos of the board if possible.
Offline mkane
Reply #10 on: February 25, 2015, 10:36:57 AM
  I'm going to need a few beer's when this get sorted and I thought yesterday was stressful
Reply #11 on: February 25, 2015, 10:38:57 AM
It's tough to tell, but be sure the UF4007's are oriented correctly.
Also, the PJCCS on the Quickie 1.1 won't work unless the D cell batteries are properly oriented.
Offline mkane
Reply #12 on: February 25, 2015, 10:53:07 AM
« Last Edit: February 25, 2015, 11:40:03 AM by mkane »
Offline mkane
Reply #13 on: February 25, 2015, 02:21:51 PM
    Nothing from side A. Bit of touch up and there's no hum, B side work's. Voltage still a bit high.
« Last Edit: February 25, 2015, 02:47:24 PM by mkane »
4krow
Reply #14 on: February 25, 2015, 07:14:09 PM
 I'll take one stab here. See the solder joint 'IA' .  Hard to see from the photo, but it may need a bit more solder. I feel your frustration, as I have done a few of these and wonder how the hell I ever ended up with a problem with such a seemingly simple circuit.
