Bottlehead Kits
BeePre
Another wonderful beepre (and 6BQ5 tube question)
kaleb
2933
kaleb
Newbie
March 11, 2015, 01:15:29 PM
I finally finished my Beepre build ordered back in Oct (somehow there was never quite time at home with an 11month old
Similar to this thread, I found A1/B4 resistances climbing into the 500Ohm-1kOhm range instead of dropping to 4Ohm:
http://bottlehead.com/smf/index.php?topic=7522.msg72511#msg72511
[nofollow]
I pushed ahead to voltage measurements. All are in spec except for C3/D3 on the nine-pin sockets. I measure 9.2V on C3 and 4.5V on D3. The high value moves with the 6BQ5 if I swap them.
It sounds beautiful, but does 9.2V at C3 on one of the 6BQ5's indicate a problem I should replace the tube for?
Thanks in advance! Kaleb
Last Edit: March 11, 2015, 01:27:46 PM by kaleb
Paul Birkeland
Global Moderator
Hero Member
Re: Another wonderful beepre (and 6BQ5 tube question)
Reply #1 on:
March 11, 2015, 04:14:19 PM
The important thing about the C3 voltage is that it's above 3V and below 32V, but otherwise it isn't very critical.
kaleb
Newbie
Reply #2 on:
March 11, 2015, 04:40:22 PM
Good news. Thank you! The beepre is running great - only a few hours of burn in so far and it is magic.
Kaleb
Bottlehead Kits
BeePre
