Ground buss instead of Terminal Strip
galyons · 4296
Offline galyons
  • Geary Lyons
on: March 22, 2015, 05:00:43 PM
Would there be any issues using a star ground or ground buss made from 10 or 12 gauge bare copper wire instead of building one  from the terminal 21-25 strip?  I thought of doing that on the Eros tape, but just stuck with the terminal strip. I would still use the 4/40 screw to mount the tab holding the buss wire.
Unless I am missing something in the instructions there is not much, other  than grounds, on the 3 strips T16-T30.  The signal input leads at T19 & T27 seem to be the only non ground connections in  the 3 terminal strip row.
I don't see any resistance checks or voltage checks on the 3 strips.  Seems to me the buss would be simpler, but don't want to create issues down the road.  Am I off the reservation here?
Cheers,
Geary
Offline galyons
  • Geary Lyons
Reply #1 on: March 25, 2015, 03:02:29 PM
snip... Am I off the reservation here?
Cheers,
Geary
This silence must be the "sound" of one hand clapping "off the reservation"!   ;D
Cheers,
Geary
Reply #2 on: March 26, 2015, 12:01:18 AM
Geary,
I don't remember that Eros uses a star ground.  It uses a running buss of twisted wire.
You could increase the size of the wire but it wasn't easy to weave the smaller wire in and out of the lower terminals.  A larger wire might not fit the lower terminal holes or might be too hard to weave in and out.
Offline galyons
  • Geary Lyons
Reply #3 on: March 26, 2015, 05:05:23 AM
Geary,
snip...
Yes, weaving the thin buss wire into the terminal strip is exactly what I am trying to avoid.  A heavy single wire ground buss would be, perhaps, a bit easier.  There are 3 terminal strips for T16-T30.  T20-T26 becomes the ground buss.  T19 and T27 are the input grid stoppers.  T16, T17,T18 and T28,T29,T30 are all unused. So my thought is to build a ground buss with a  non-grounded terminal at each end for the grid stoppers.  I was just looking for some validation on the circuit implementation. I think I am reading the schematic and the manual correctly, but sometimes....  (BTW, my Eros tape used most of those unused terminals for the EQ circuits!)
Cheers,
Geary
Reply #4 on: March 26, 2015, 06:22:54 AM
The pictures are great to determine what is where.
Offline galyons
  • Geary Lyons
Reply #5 on: March 27, 2015, 04:47:36 AM
So true!  I am a "Visual". Gotta see it to "get" it!!!
Geary
