Noise on one channel with certain kinds of music only
Al Campone · 1382
Offline Al Campone
Help!!
I finished assembling my bottlehead crack some weeks ago and had a couple of really wonderful hours listening to my music -- until.... I stumbled over one song where some (yes: a faint CRACKle) noise occurs.
The noise is reproducable, but occurs only during certain, rather loud passages of the song. It is a rather ambient song (Lustmord: Babel); I exchanged the main tube without effect and resoldered (as good as I could) - also without effect. The noise is not in the song itself (tried with the same headphone on a different amp).
Is there somebody with a similar problem?
Would it help to install the speedball upgrade or would this just increase the complexity of the problem?
Thanks a lot for any helpful comments...
BW
Reply #1 on: March 26, 2015, 11:15:19 AM
This is almost certainly a flaky solder joint, I would go over them very carefully with your iron, being sure that they are all flowed and tight.
Offline Al Campone
Reply #2 on: March 26, 2015, 11:18:16 AM
I just did that... but maybe not thorougly enough... is there a part of the circuit that is more likely to produce this kind of problem?
Thx!!
C
Reply #3 on: March 26, 2015, 11:35:31 AM
Loud passage, just one song - you're probably just clipping the amp.
Offline Al Campone
Reply #4 on: March 26, 2015, 12:15:55 PM
Hm.... I don't think so because the noise seems somehow decoupled from the music. I would expect that clipping rather produces a distortion of the music itself?
Will check if the noise vanishes with lower input or output levels and if it makes a difference if input channels are exchanged...
