Speedball Help
Blkout · 9194
Offline Blkout
on: March 29, 2015, 12:36:37 PM
So I just got the Speedball installed, vacuum tubes light up fine, however I don't have sound in the right channel or if I do, its very low volume compared to the left. I noticed that one of the smaller PCB's next to the headphone input jack which has two LED's, only one of the LED's is lighting up, I removed it to make sure it was installed in the right direction which it was and reflowed all of the solder joints on that PCB just for good measure. It still doesn't light up. Could this be the cause of my right channel problem or should I look deeper? I also checked the 2N2222A and 2N2907A transistors and they're installed in their correct positions, so there's no mix-up there if that helps. Any suggestions from your guys or PB on this would be greatly appreciated.
Thanks.
FYI, my Crack has been running fine for the last 2-3 months now before I installed the Speedball.
« Last Edit: March 29, 2015, 12:41:07 PM by Blkout »
Reply #1 on: March 29, 2015, 01:08:59 PM
Start by taking voltage measurements and posting those that are out of specification.
Offline Blkout
Reply #2 on: March 29, 2015, 01:40:37 PM
OK Paul,
T1. 168v - supposed to be 75-90v
T7. 165v - supposed to be 100v
T21. 217v - should be within tolerance but noted anyway
A1. 73v - supposed to be 90v
A6. 168v - supposed to be 90v
B1. 168v - supposed to be 90v
B3. 165v - supposed to be 100v
B4. 73v - supposed to be 90V
All of the others are either dead-on or very close.
Thank you.
« Last Edit: March 30, 2015, 04:06:57 PM by Blkout »
Reply #3 on: March 30, 2015, 02:46:40 PM
Do both LED's on the 9 pin socket light?  (If one doesn't it's probably not the LED, so no need to resolder it necessarily)
Offline Blkout
Reply #4 on: March 30, 2015, 03:23:55 PM
Paul, both LED's light on the 9 pin socket and all of the Speedball LED's are lit except one of the two on the small PCB nearest the headphone input jack.
My biggest concern is that when I was installing the Speedball, I didn't have a lot of room for the nylon stand-offs around the tube sockets so I had to move some wiring around to make room for them and I'm concerned that I may have weakened or broken a solder joint even though visually they look ok.
But I still have no idea what could be causing the voltages to be so far off on the terminals and tube terminals I listed above.
« Last Edit: March 30, 2015, 03:32:12 PM by Blkout »
Reply #5 on: March 31, 2015, 06:56:50 AM
Check that you haven't swapped your R1's accidentally.
(One LED on the 9 pin socket would be quite a bit brighter if this was the case)
Offline Blkout
Reply #6 on: March 31, 2015, 08:21:28 AM
Paul, feel free to call me a moron but what part is R1? Yes one LED on the 9 pin socket is much brighter than the other.
Reply #7 on: March 31, 2015, 08:24:07 AM
Check the Speedball manual and resistor installation.
Offline Blkout
Reply #8 on: March 31, 2015, 08:31:35 AM
Paul if you're talking about the R1's on the small PCB's for the Speedball mod, then both are correct, 237ohm resistors at R1 positions. Both read 237ohm resistance with the meter.
Offline Blkout
Reply #9 on: March 31, 2015, 09:27:16 AM
And pictures, just in case this helps.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi61.tinypic.com%2F1441o3c.jpg&hash=2b87093e5359dd674e8cbae62c9746d02d35accb)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi61.tinypic.com%2Frm7421.jpg&hash=2fc69a31777cd94819dafc8302bc18ab0218c791)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi60.tinypic.com%2F2cest34.jpg&hash=b04a7ffff11ddecbfb38dff72f323f9c19014e67)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi60.tinypic.com%2F2mxzqw.jpg&hash=da403dc152b60109657c09bbcf7c4d51687e6cbd)
Reply #10 on: March 31, 2015, 09:37:30 AM
Can you see if the LED that is not lighted is in the proper orientation.  That is, the silver band toward the flat side of the painted circle?
This is the reason that the manual instructs you to mount them upside down.  It was a popular mistake till the upside down mounting was suggested.  This allows you to easily see the orientation.
Reply #11 on: March 31, 2015, 09:42:18 AM
Flip that A board over and inspect the solder joints. In particular look for missing solder or solder bridged pads around the 2N2907 transistor and the LED
Reply #12 on: March 31, 2015, 09:45:40 AM
I would suspect a solder bridge on the bottom side of the board if the R1's are correct.
Also, FWIW, the instructions say to put the LED's in with the stripe facing up so it's easy to see that they are all properly oriented.
Offline Blkout
Reply #13 on: March 31, 2015, 09:50:58 AM
I've already removed that LED that isn't lighting and checked its orientation and its correct. I double checked and triple checked them before installing them.
Will do and report back.
I will check the R1's from the bottom again. And I knew I would probably catch Hell for installing those LED's the other way. I know the instructions said to install them face down but I wanted it to be a bit prettier and I figured if I was absolutely sure they were orientated right, it should be fine. However, I didn't count on having a problem with the installation. I can guarantee that the LED's are orientated correctly though.
« Last Edit: March 31, 2015, 09:53:24 AM by Blkout »
Offline Blkout
Reply #14 on: March 31, 2015, 10:15:56 AM
Reflowed all solder joints on the A board. Didn't see any bridges and the R1 looks fine to me. Here's a backside picture of the A board.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi59.tinypic.com%2F5bpv81.jpg&hash=94e1114ce33eeebd47e638b7cd0b0afed30acdb1)
