High voltage during voltage check
RW · 4665
Reply #15 on: April 02, 2015, 01:01:49 PM
So it's safe to move forward with the speedball?
Thanks again for all the help. All of you BottleHeads kick ass
Yeah, I'd run the amp over the weekend, then proceed if all is still well.
Offline RW
Reply #16 on: April 02, 2015, 01:35:13 PM
Grainger, I have a diode tester on my meters. I will test it to see what's up. If it is bad, I should replace it, correct? I would have to remove that jumper that PB had me add if the LED is being replaced? Thanks for the help and input.
PB, ok, I'll run it for a few days. Unfortunately I'm not a fan of my headphones that I have for it (650s) so I'll just let it run a playlist for a few hours on its own, I'll just leave the headphones in so it has a load. Thanks for the help, I certainly appreciate it
