Bottlehead Kits
Crack
Problems after installing Speedball
jazzfan78
3227
jazzfan78
Jr. Member
March 31, 2015, 04:57:34 AM
well. i installed speedball and i still didnt do the voltage checks. but i notice not all the LEDS on speedball boards in working.
in the crack the LEDS in working fine. the problem is on the speedball boards.
pictures:
1) in the two A and B pc poabrs both left side leds dont glowing but right is fine
http://tinypic.com/view.php?pic=291jn7l&s=8#.VRq1qvmUdyw
2) in the Big main speedball board in the left side the 2 leds dont work but in the right side the 2 of them is ok.
http://tinypic.com/view.php?pic=xbh64j&s=8
what is the problem?
jazzfan78
Jr. Member
Re: Problems after installing Speedball
Reply #1 on:
March 31, 2015, 06:27:03 AM
i had this multimeter which i need to choose DC
V---
or V~
and which number?
pic:
http://i57.tinypic.com/o5dct4.jpg
fullheadofnothing
Global Moderator
Hero Member
A noble spirit embiggens the smallest man
Reply #2 on:
March 31, 2015, 06:49:03 AM
The straight line is DC, the squiggly line is AC. m means milivolt. No letter means volts. Choose the next range higher than what you expect (i.e. if you're expecting 190V, use 200, if you're expecting 205V, choose 500, et cetera).
Grainger49
Hero Member
Reply #3 on:
March 31, 2015, 06:49:53 AM
The only AC readings are the power supply up to the rectifiers for the high voltage and the heaters for both tubes.
Did the Crack work before the Speedball upgrade? If so you need to give the voltages at the circuit boards (all DC) where the PCBs are attached to the circuit.
Blkout
Jr. Member
Reply #4 on:
March 31, 2015, 09:06:06 AM
Pretty sure that the R2 resistors are wrong in this picture in the bottom right hand corner, it's the two pair that were supposed to be twisted on one end and clipped. It looks like the R2 pair on the upper left hand side are correct, but the bottom right should be the same.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi57.tinypic.com%2Fxbh64j.jpg&hash=5b9291db71b74c5e0869a1af8db069c6bf26410e)
Last Edit: March 31, 2015, 09:08:19 AM by Blkout
jazzfan78
Jr. Member
Reply #5 on:
April 20, 2015, 12:36:33 AM
i have serious problem. i try to measure. and my measures readings is really wrong. the crack worked without the speedball. now all the readings is a mess.
i upload here photos of the board in front and backwords if you guys can identify if something wrong. thnx!
A and B boards
http://oi58.tinypic.com/i4qt5u.jpg
big board
http://i62.tinypic.com/161ja1l.jpg
A board back
http://oi61.tinypic.com/217xvp.jpg
B board back
http://oi59.tinypic.com/2ihuq6r.jpg
Big board back
http://oi58.tinypic.com/5zmwqg.jpg
Rocketman248
Full Member
Reply #6 on:
April 20, 2015, 01:49:19 AM
You've got some pretty big solder blobs on there. Look very closely to make sure nothing is shorted together.
Nick DeBrita
Yokosuka, Japan
Paul Birkeland
Global Moderator
Hero Member
Reply #7 on:
April 20, 2015, 07:25:07 AM
You need to trim the leads on the back sides of the boards
much
closer to the board itself. Look at the photos in the manual and do your best to imitate what's there. (You also have an awful lot of solder on there, as mentioned before)
Loggie
Jr. Member
Reply #8 on:
April 20, 2015, 08:27:28 AM
I noticed there are two different sets of resistors on the main PCB.
Do the smaller ones have the same value as the larger (brown) ones?
See attached picture (circled both sets red)
Also it looks as if the 2N2222 solderpoints almost touch eachother (but it could also be the angle of the picture that gives that impression).
Edit: Just noticed that Blkout also made the observation about the 2 different pairs of resistors!
Last Edit: April 20, 2015, 08:31:10 AM by Loggie
Arno
Bottlehead Crack--Lenco L76-Thorens TD147--Cyrus IIIi+PSX-R--KEF Q7--Klipsch R-26F--Marantz CD72 SE--Philips CD202--Musical Fidelity XLPS V3--CNC Phono Stage
Bottlehead Kits
Crack
