impedance switch
rbc3 · 5650
Offline rbc3
on: April 01, 2015, 01:56:28 PM
I'm thinking about installing an impedance switch in my Paramount.  I saw an old thread where Paul (I think) posted a circuit diagram for installing one, but the image isn't in the thread anymore.  Can someone repost it?  Also can someone recommend a 2-pole 3-position switch that will work?
Thank you,
Robert
« Last Edit: April 02, 2015, 10:02:03 AM by rbc3 »
Robert C
Paramount 1.1 300B, Tekton Design Seas Pendragon, Stereomour 2A3, Omega Hemptone 8, Acoustic Signature Challenger Mk3, JMW 9T, Dynavector XX2mkII, Clearaudio Balance, Quickie 1.1, Schiit Bifrost Uber, Mainline, Audeze LCD2.2, AKG K1000, HiFiman HE-500, Sennheiser HD650, AK120
Reply #1 on: April 01, 2015, 04:57:17 PM
Finding this image was pretty tough!  (PJ sent it to my on a prior e-mail account, so I had to go digging through the internet to grab it)
Do note that this will only work with the Paramount output transformer (Not the SEX, Stereomour, Mainline, etc.)
We had to buy several thousand 4P3T rotary switches for our kits to get what we wanted, I'm sure we could put together a little parts order for you.
« Last Edit: April 01, 2015, 04:59:15 PM by Caucasian Blackplate »
Reply #2 on: April 01, 2015, 06:27:36 PM
But the OP said Paramour.
Which version? What output transformer? There have been quite a few of them ...
Offline rbc3
Reply #3 on: April 02, 2015, 10:04:00 AM
Sorry I mis-typed.  I have a pair of Paramount 1.1 300B.  The output transformer is labelled OT-1, but I suspect that is just for build instructions.  How can I ID it?
« Last Edit: April 02, 2015, 10:07:26 AM by rbc3 »
Robert C
Reply #4 on: April 02, 2015, 02:20:06 PM
OT-1 is our designation for the stock transformer (my design). PB posted the correct circuit above for switching output impedances on that transformer.
Offline rbc3
Reply #5 on: September 13, 2015, 06:06:36 PM
Today I finally got around to wiring up the rotary switches to my 1.1 Paramounts so that I can switch between 4 ohm, 8 ohm, and 16 ohm impedance.  I custom made some brackets and mounted them to the OT-1 output transformers so that the left position is 4 ohm, the middle position is 8 ohm, and the right position is 16 ohm.  Here are the details of how I wired them for anybody else who wants to add this mod using a 4P3T (4 pole 3 position) switch.
The pin connections for each position are:
Position 1 (left)
    A -> 1
    B -> 4
    C -> 7
    D -> 10
Position 2 (middle)
    A -> 2
    B -> 5
    C -> 8
    D -> 11
Position 3 (right)
    A -> 3
    B -> 6
    C -> 9
    D -> 12
Since the impedance switch only needs two poles here is how I wired my switch so that left is 4 ohm, middle is 8 ohm, and right is 16 ohm.
OT-1 terminal 1 -> switch pin B (red wire)
OT-1 terminal 2 -> switch pin 1 (black wire)
OT-1 terminal 3 -> switch pin 5 (red wire)
OT-1 terminal 6 -> switch pin 2 (black wire)
OT-1 terminal 7 -> switch pin 4 (red wire)
OT-1 terminal 8 -> switch pin A (black wire)
switch pin 6 -> switch pin 3 (black wire)
All together it looks like this:
Position 1 - left - 4 ohm
   OT-1 8 -> pin A / pin 1 -> OT-1 2
   OT-1 1 -> pin B / pin 7 -> OT-1 7
Position 2 - middle - 8 ohm
   OT-1 8 -> pin A / pin 2 -> OT-1 6
   OT-1 1 -> pin B / pin 5 -> OT-1 3
Position 1 - right - 16 ohm
   OT-1 8 -> pin A / pin 3 -> pin 6
   OT-1 1 -> pin B / pin 6 -> pin 3
Here are some picks:
https://www.dropbox.com/s/3c1ch25rsgtxjpr/20150913_142632_HDR.jpg?dl=0
https://www.dropbox.com/s/d36mzl0vxrwy7rk/20150913_142649_HDR.jpg?dl=0
Robert C
