Goldpoint resistors
glassglow · 2580
Offline glassglow
on: April 03, 2015, 08:47:10 AM
I'm building up a Goldpoint attenuator for the Crack. I have a mix of both Dale RN55 (1/8 watt) and RN60 (1/4 watt) to cover the resistance values needed. With 100K total resistance and a typical 2V CD player output I'm thinking the 1/8 watt resistors should easily cover the power requirements. Am I correct?
Reply #1 on: April 03, 2015, 08:52:19 AM
Yes, you are right.  The 100k Ohm resistance doesn't draw appreciable current.
Reply #2 on: April 03, 2015, 09:33:21 AM
Ohm's Law says that with 100,000 Ohms and 2 Volts across it, total power dissipated is 0.00004 Watts (on the whole 100K string). For some safety margin, you would want a resistor rated to dissipate 0.00012 Watts.  The lowest wattage rating I see on Mouser is 0.001 Watts, so you should be fine with just about any resistor in existence, at least from a power perspective.
Offline Chris65
Reply #3 on: April 03, 2015, 12:59:02 PM
I have a mix of both Dale RN55 (1/8 watt) and RN60 (1/4 watt).....
The Dale Mil-spec is very conservative, in commercial versions the '55' is rated at half watt & the '60' at 1 watt.
