Help with Resistance Checks [solved]
Stedes · 4578
Offline Stedes
on: April 13, 2015, 02:14:30 AM
Hi everyone,
Just completed my second ever kit, a Stereomour, having completed a Smash late last year.
Doing the resistance checks I have the following discrepancies which I'm not sure are ok:
2) 17 MOhms
19) 20 MOhms and then value slowly decreases
A2) 7 MOhms and then value slowly decreases
C2) 4 MOhms and then value slowly decreases
For all 4 of the above the manual states "infinite" value which is denoted by Od on my multimeter. They are fairly big values (which is good) but I'd like to make sure I'm safe to proceed to the voltage checks. If someone could reply and let me know that would be appreciated.
Thank you.
« Last Edit: April 15, 2015, 07:15:43 AM by Caucasian Blackplate »
Reply #1 on: April 13, 2015, 04:29:30 AM
I don't have a Stereomour or even a manual.  But...  any reading over 1M Ohm should be considered infinity.  Also, any reading marked * is considered good for the readings you got.
Offline Stedes
Reply #2 on: April 15, 2015, 04:45:00 AM
Thank you very much...I thought that's probably the case but it's always better checking.
Voltage checks were good, hum pots adjusted and music is playing...very nice indeed.
Offline mkane
Reply #3 on: April 15, 2015, 09:39:37 AM
  Indeed it is. Wondering if the II could possibly sound better
Reply #4 on: April 15, 2015, 01:40:11 PM
I don't expect the II to sound different, in stock form. It just has greater upgradeability.
