Quickie Output Coupling
Bonzo · 4577
Offline Bonzo
on: April 17, 2015, 04:35:11 AM
Ok!
I've found a pair of UTC A20...
I know they can't stand any DC, but do you, Master Technician of Bottlehead Forum, think I can use them as coupling transformer in my Quickie?
Just to explore :-)
Bisogna avere orecchio!
Reply #1 on: April 17, 2015, 05:58:05 AM
The A-20 is a 600:600 Ohm line transformer with lots of taps on both windings.  This is not suitable for the Quickie.
Offline Bonzo
Reply #2 on: April 17, 2015, 06:14:28 AM
ouch!
So I sick with the original project: to substitute Edcor 10k:10k transformers in my diy dac  :)
Thank you and sorry for my dumb question!
Reply #3 on: April 17, 2015, 06:24:49 AM
It's not a dumb question.  Are you looking for balanced outputs, or lower impedance outputs?
I think 10K:10K is even a little low for the Quickie, but there are others that will work well running 15K:15K, or even higher (they just cost as much as the Quickie, or more!)
Offline Bonzo
Reply #4 on: April 17, 2015, 07:57:20 AM
I was thinking of a quick wat to test the transformers and to compare capacitor and transformer coupling.
But what you wrote is right, output transformer aren't cheap, and output transformer for line level preamp are outrageous expensive (like the ones for Euridice diy preamp).
Well, changing subject, what about a battery phono preamp to match the "Quick*" serie?
 ;D
Reply #5 on: April 17, 2015, 08:05:33 AM
I've looked into a battery tube phono preamp several times, and have not yet come up with anything I'm happy with - between the microphonic issues and the low gain of available tubes (causing many tubes and more battery drain). But we'll keep going back to the issue.
Offline Bonzo
Reply #6 on: April 17, 2015, 08:20:20 AM
Wow...
I can only say wow...hope this dream come true soon
Keep the good work!
Thank you!
Reply #7 on: April 17, 2015, 08:37:17 AM
If you like the Euridice, you'd probably enjoy the Mainline.
Offline Bonzo
Reply #8 on: April 17, 2015, 09:27:07 AM
Mainline you said? Isn't Mainline a headphone amp only?
Reply #9 on: April 17, 2015, 10:05:47 AM
Yes, it is a headphone amp.  It has the transformer coupled single gainstage topology similar to the Euridice, but with a shunt regulated power supply, parallel feed outputs, etc. etc. (and more power!)
