Should the R and L RCA center pin have the same resistance?
Nehan · 5086
Offline Nehan
Greetings.
I get 95k in the right RCA (red) and 94.1 in the left (white).
Reply #1 on: April 20, 2015, 04:07:44 AM
You are reading the slight differences in the full range of the stereo pot.  It is inconsequential.  If you had a stepped attenuator using discrete resistors they would probably not be the same but might be a little closer.
Offline Nehan
Reply #2 on: April 20, 2015, 04:18:02 AM
So I won't notice a difference in the sound (volume) between both channels?
Thanks you for the quick answer.
Reply #3 on: April 20, 2015, 05:26:26 AM
Right, at that resistance it takes much more to make the center image off to the right or left.
However... there is always exceptions.  I find many recordings off center.  It isn't the system, it is the recordings.
Offline Nehan
Reply #4 on: April 20, 2015, 06:41:54 AM
Thanks you very much sir.
In the TRS jack check, the voltage never drops to 0. Instead, it fluctuates between 0.00 and 0.07. Is it ok o it have to be always 0.0?
Reply #5 on: April 20, 2015, 07:27:05 AM
That's certainly close enough to call it 0.
Offline Nehan
Reply #6 on: April 20, 2015, 07:30:46 AM
Thanks you for the clarification.
Offline Nehan
Reply #7 on: April 21, 2015, 05:34:05 AM
Hi there.
After install the speed ball, the voltage at the TRS check goes up to almost 20v. quickly, and then drop to 0.0v -0 .07v. Are those 20v. a problem or are not that high to be dangerous for the headphones?
Reply #8 on: April 21, 2015, 07:05:38 AM
That's normal.
Offline Nehan
Reply #9 on: April 21, 2015, 07:21:02 AM
I should read before asking. I'm sorry. I "fixed" it with this: http://bottlehead.com/smf/index.php?topic=2946.0.
I am very happy to have my amp finished. Thanks everybody for the help!
By the way, a little background noise at music silences is normal in a tube amp, right?
Reply #10 on: April 21, 2015, 07:32:45 AM
Hmm, tell us about your headphones and audio source?
A poorly soldered 220uF/250V capacitor can lead to an amp with perfect voltages and perfect functionality, but noisy at the same time.
The Crack, with the volume control turned all the way up, will make some noise into most headphones.  Of course, if you played music into the amplifier with the level control up this far, it would be unlistenably loud (which is why the noise is there in the first place).
Offline Nehan
Reply #11 on: April 21, 2015, 07:56:46 AM
The path is PC > ODAC RCA > Crack > Sennheiser HD600.
Is better to have the PC volume at max, and the crack volume low?
I'll try resoldering the 4 caps.
Reply #12 on: April 21, 2015, 08:35:36 AM
Yes, you want the source level as high as it can be, as that helps improve the signal to noise ratio of the overall system.
Offline Nehan
Reply #13 on: April 21, 2015, 08:56:57 AM
After resolder the caps, I was checking the voltage and something exploded. What I have to do?
Edit: I checked the pin 1 and 2, and the values were better than before (1 = 80v., 2 = 170v.), but in the pin3 something exploded. I don't know if I touched something else.
« Last Edit: April 21, 2015, 09:01:31 AM by Nehan »
Reply #14 on: April 21, 2015, 09:27:03 AM
When you say exploded do you mean you saw a spark? That would be from touching the probe from a live terminal to another terminal, or ground. If the voltages are OK and it sounds OK no harm was done.
