Reduction Build Question Phase
SCompRacer · 3929
Offline SCompRacer
on: May 02, 2015, 05:23:59 AM
Greetings all. Aaron, ALL212, has convinced me I need a Reduction w/Integration upgrade so I ordered one. Does the Reduction invert phase? I see phase is not inverted with the Eros but didn't see anything mentioned for the Reduction. It sure sounded good and I failed to try the invert phase on my pre amp to see if it made a difference.
I'll be using a two speed DIY Cinemag SUT with an AT33PTG/II cart (.3mV). The sweet spot is on high, or 30dB, with Aaron's Reduction/Integration build in my system. It sounds fantastic for the money invested in it. He pushed me to get an Eros but I think it would be too much gain (80dB) with my SUT.
Rich O
Salk SoundScape 8's * Audio Research Ref 3 * Krell KSA-250 Amp * Bottlehead Eros * Park's Audio Budgie SUT * DIY Buffalo III Dual Mono DAC * Heavy Plinth/Platter Lenco Idler Drive * Phoenix Eng 25W Power Supply & RoadRunner Tach * Advanced Analog MG-1 Linear Air Bearing Arm * AT33PTG/II
Reply #1 on: May 02, 2015, 06:38:43 AM
No, the phase is inverted then restored in the two sections of the tube(s).
Offline SCompRacer
Reply #2 on: May 04, 2015, 05:30:32 AM
Thank you Grainger!
I should have listened to Aaron in the first place. I sent an email cancelling the Reduction and to order an Eros instead.
Rich O
