Power supply question
Costes · 2225
Offline Costes
on: May 13, 2015, 09:30:06 AM
Hi all!
I was doing some modifications to the power supply (jantzen 220uF cap, 2 triad C7x chokes), so i disconnected the B+ output from the rest of the audio circuit. So basically i isolated my power supply from the rest.
Before connecting it again i did a resistance check of the power supply (Terminal-11 till T-22) which was oke,
but now my question  :)
The voltage check of these Terminals was as following:
T-11 0v
T-12 0v
T-13 210v
T-14 0v
T-15 210v
T-20 0v
T-21 210v
Are these values to be normal/expected from the power supply, if it is disconnected or has no load?
Reply #1 on: May 13, 2015, 01:08:07 PM
Yes.
Offline Costes
Reply #2 on: May 14, 2015, 05:33:38 AM
Thank you  :D
