Power transformers painting concerns?
Michael415 · 18747
Offline Michael415
on: June 09, 2010, 09:41:51 PM
Recently ordered the kit and have started doing some research for several cosmetic aspects. I have noticed that many of the modded amps the power transformers were left as is and was wondering is there a specific reason? If I decide to paint or cover the yellow part (thinking of attempting to polish the metal) are there any concerns? Would it need to be high temp paint? Basically I am unsure what parts get warm enough for concern.
Thanks in advance!
Michael Davis
Rega Saturn|Moon Amp|Monitor Audio PL100's
NAD 542|S.E.X. Amp (in process)|Grado phones
Reply #1 on: June 10, 2010, 02:47:05 AM
Check in the Gallery.  I believe Wardsweb has colors on both the top plates and end of the laminations of some of his transformers.  He often posts the method he used.  If not, post asking and I'm sure he will answer.
I have been looking for gun bluing for the end bells on my Paramours.
Offline Michael415
Reply #2 on: June 10, 2010, 04:06:24 AM
I had noticed he had modified them but so far is about the only one I had found. I will definitely drop him a line though thanks!
Michael Davis
Online Doc B.
Reply #3 on: June 10, 2010, 05:15:29 AM
You can paint the output transformers, they don't get that hot. I've done various treatments over the years, one of the more visually successful was covering the yellow wrap with leather. I've also used a little flocking kit you can buy at craft stores. You paint a base color paint on and then coat the wet paint with the flocking, which is puffed out of a bottle onto the surface.
Just be sure to mask the wires before spray painting, so you can identify them when you assemble the amp.
Offline Michael415
Reply #4 on: June 10, 2010, 05:41:36 AM
Great Ideas Doc, thanks!
Will definitely check out the flocking, but the leather idea sounds great.
Michael Davis
Reply #5 on: June 10, 2010, 05:44:25 AM
I got the visual of flocked wires.
Thanks for the image, it made me chuckle.
