Uh oh- something went wrong- RESOLVED
Nathan · 2184
Offline Nathan
on: May 20, 2015, 05:18:37 PM
So I installed a switchcraft 152b headphone jack today. Put a 2.49k resistor between tip and sleeve and between ring and sleeve.
Had to lengthen the wires to the 152b so I soldered a few more inches of wire to the red, black and white wires.
Turned everything on and there's a deep hum in the right channel. Same whether or not anything is plugged into the right input jack.
I accidentally broke one connection from the small speedball board closest to to jack but I re soldered it back.
Thoughts? I'm sort of crestfallen that my crack isn't working right
« Last Edit: June 20, 2015, 05:03:07 PM by Nathan »
Crack/Speedball & SEX 2.1/C4S
Offline grausch
Reply #1 on: May 20, 2015, 10:37:48 PM
I am no expert and I think one of the Bottlehead crew would be much better at helping here. I also don't have the Speedball installed and don't know how this will affect your resistances. However, I can note that with my Crack there is no hum. In both the original and rebuilt Crack, I did not lengthen any of my wires. All of them were replaced with the appropriate length of wire from the leftover wire I had from the original build.
Assuming that this relates purely to the insertion of the headphone jack, have you reflowed the solder joints you worked on? Are all of the places you lengthened the wire well insulated and not grounding to the chassis? I may be completely off-track here, but I believe it is crucial that there is only one point to ground (RCA jacks in the case of the Crack).
Also, have you checked the ground path (http://bottlehead.com/smf/index.php?topic=4812.0) - I would start off with the areas you worked on. Usually you would have 2.49Kohm of resistance measuring from T6/T10. Don't think you can access those with the Speedball installed, but could you measure those resistances elsewhere?
That is really all I can think of, and if that does not indicate any problems, then the experts would need to assist.
Gunter Rausch
Modded Bottlehead Crack
Modded Stereomour with Two-tone Orcas
Offline Nathan
Reply #2 on: June 20, 2015, 05:04:08 PM
Here's what happened. One red wire to the small board nearest the volume pot broke when I was moving things around to wire in the new headphone jack.
Reply #3 on: June 20, 2015, 06:54:13 PM
The wire breaks when you set the wire stripper too small and it nicks the copper, creating a weak point.
