Extended FP3 Adapter for 9 pin to Octal
Nutube · 21863
Offline Nutube
  • AudioAddicted-RefuseRehab
on: June 10, 2010, 05:54:49 AM
Folks
I am making an adapter to plug into existing 9 pin...... both boards and tube don't light up. Regulator is fine. I have transposed and connected 8 pins Dont laugh --I left it out . Tested just to see if things light up. Reinstalling the 12au7 all went well...
where do I connect the 9 pin to on  6sn7 socket. Isn't the nine supplying the power ?
As usual I am exposing my fundamental logic impairment. Your advise is needed
FP 1,2,3, Seduction, 45, Paramount 300B, Paraglow2A3; Dehavilland 845, Eico pp 805,Adcom 555 mono, Sota star saphire ugraded Nova motor & bearings,  Et 2.5 carbon wand on Shelter 901, Koetsu rosewood Sig., on magnesium wand, grado sumiko etc. Custom Edgarhorn with Seismic sub
Reply #1 on: June 10, 2010, 06:57:56 AM
Pins 4/5 and pin 9 on the 9 pin socket are the heater connections.  On the 6SN7, the heaters are pins 7 and 8.
Offline Nutube
Reply #2 on: June 10, 2010, 07:50:14 AM
PB
Does the #9 pin of the 9 pin socket wire hook to the  octal 7 or 8 pin and then tie 8 & 7 togather?
Currently I have the 4 to 7; 5 to 8 and nothing on the #9 of 9 pin thinking the power is already distributed by the existing #9 on the 12au7 socket on the chassis
Reply #3 on: June 10, 2010, 07:51:35 AM
4 and 5 are tied together at the 9 pin socket, so going 4 to 7 and 5 to 8 puts 0v AC on the 6SN7 heaters.  The 6.3v appears between pins 4/5 (which are tied together) and pin 9, so go pin 4 to 7 and 9 to 8, or pin 5 to 7 and 9 to 8.
Reply #4 on: June 10, 2010, 08:41:23 AM
If you are making an adapter yourself the existing FP III pin 4 and 5 (first heater lead) are one and the same, voltage wise.  Either of them can go to the 6SN7 socket 7 OR 8.  The existing FP III pin 9 (other heater lead) goes to the other one of 7 OR 8.
For proximity and simplicity sake take the existing FP III pin 5 to the octal pin 7, take the existing FP III pin 9 to the octal pin 8.
Offline Nutube
Reply #5 on: June 10, 2010, 12:20:48 PM
I got it lighted! I need to improve the design...Its kinda pain to get to the wires for trouble shooting. Have a new design but thought I'd take a rest and move to another project while listening.
Off topic- I went to the gallery and could not find instruction on how to post pictures- Can you guys sic me on to it- Thanks
Reply #6 on: June 10, 2010, 01:04:24 PM
Don't feel rained on.  I had the same problem till I had posted several pictures.  When starting a topic there is an option at the lower left called "additional options."  There there is the "Attach" hot key that allows you to upload a picture.
If posting a reply you have to go to the "Preview" page first and then "additional options" hot key is there.
« Last Edit: June 10, 2010, 01:06:20 PM by Grainger49 »
