Noisy sex
RW · 16600
Offline RW
Reply #45 on: October 16, 2015, 05:01:42 PM
@Mc
Good call! Thanks for spotting that! I don't know how I missed it, I went thru this manual a bunch. That solved the voltage on the jack leads. Unfortunately, the hum is still there.
Reply #46 on: October 17, 2015, 03:12:51 AM
Can you do as Doc asked and remeasure the AC voltages using the headphone socket ground.
Offline RW
Reply #47 on: October 17, 2015, 05:01:09 AM
I did, there's no voltage. Even if I use lug 13, it still reads 0v
Offline RW
Reply #48 on: October 27, 2015, 04:24:51 PM
Hey Guys/Gals
So I need a little advice. What would be the best way to break this kit down in sections to isolate this hum? I've read just about every post in this forum, and the one solution that I haven't tried, which seemed to work for another member, was to rebuild the heater supply with a few 4700uf caps and a few resistors. I'm ordering parts to bread board it up, but I want to minimize the disassembly of the amp as much as possible, and I don't want to work on sections that are working fine? If I can't solve this hum, I'm just gonna drop the extra scratch and ship it over to the service dept to take a look at it.
Reply #49 on: October 28, 2015, 10:49:36 AM
The first thing that you absolutely need to do is to get a better multimeter.  The reading of 300mV of noise indicates that your meter can't resolve low AC voltages, so even if you could break the circuit down to isolate the noise, you can't measure it.  If at all possible, take that one back to Radio Shack (FYI - the last six meters that I bought at RS were all defective)
Try the $25-ish multimeter from Harbor Freight, or borrow a different meter from a friend, then recheck the noise at the speaker posts/headphone jack.  A very loud amount of noise in your application might be something like 10-30mV.
Offline RW
Reply #50 on: October 28, 2015, 03:28:11 PM
Is the $25 HF meter going to be able to do what we need it to? If so, I'll have it tomorrow after work. Do I need something more accurate? Ill buy the $200 millivolt meter from MCM if need be. I also have an oscilloscope at my disposal right now. I'm not a pro with it but I can make it work. If there's something specific I need to do with it, just let me know and I'll do my best to make it happen.
As always, I appreciate your help
Reply #51 on: October 28, 2015, 04:52:36 PM
I'm totally OK with helping you out while you use the scope, but the meter is a lot easier.  I don't believe you'll need anything more accurate than that meter.  I'll pick that particular one up on my way to work tomorrow and double check for you, just in case.  The $200 meter is overkill, as in that case you'd want to move to your scope to have a look.
Offline RW
Reply #52 on: October 29, 2015, 12:21:02 AM
Awesome, thanks PB! Let me know what to get, and I'll scoop it up.
Reply #53 on: October 29, 2015, 10:50:20 AM
I tested our stock SEX (no C4S, no impedance switch kit) with the $25 HFT meter, it shows 0mV of noise on the 2V scale on the speaker taps on the 8 Ohm setting.  It does seem to be able to resolve low AC voltages pretty well, so I'd say it's up for the task.
Offline RW
Reply #54 on: October 29, 2015, 12:21:48 PM
Ok cool. I'm on my way to grab it now. Just an FYI, i don't have the speaker terminals wired in, this shouldn't make a difference, correct?
Offline RW
Reply #55 on: October 29, 2015, 02:50:19 PM
I took measurements on each leg of the headphone jack. No matter the impedance switch position, they all read .004AC
Reply #56 on: October 29, 2015, 02:59:26 PM
What noise figure do you get on the other side of that resistor on the headphone jack? (crank the volume pot all the way down too)
Offline RW
Reply #57 on: October 29, 2015, 03:18:07 PM
Same, .004 on all switch positions. Volume pot was off on all measurements, including the originals.
Reply #58 on: October 29, 2015, 05:56:13 PM
Try twisting the black and red test leads together. That will cut down their tendency to pick up outside interference that might be adding to the waveform coming out of the jack, and possibly give you a lower and more accurate reading.
Reply #59 on: October 29, 2015, 06:46:14 PM
All output transformer measurements?
I'd get out the scope at this point and post up a photo of what you see on the display.
