shunt regulator slow start
Jeroen · 2952
Offline Jeroen
on: June 08, 2015, 10:45:19 AM
When testing the voltage on D1  I put the power on and after a couple of seconds all 4 LED's on the shunt regulator lit up. Then I put the power off. When putting the power on again for measuring the voltage on D6 it took 5 minutes before all 4 LED's lit up.  I did a couple of more tests and every time it took 5 minutes before the LED's starting to lit up (and the voltage on D1 and 6 drops).
Is this something I have to worry about?
Voltages on D1 and D6 are both 222 volts and hardly fluctuate.
Best Regards,
Jeroen
Reply #1 on: June 08, 2015, 11:04:35 AM
This is the important part.  The other timing issues are the 12BH7 warming up.
Reply #2 on: June 08, 2015, 11:35:33 AM
Five minutes is very slow, though. What is your power line (mains) voltage?
Offline Jeroen
Reply #3 on: June 08, 2015, 06:30:44 PM
Line voltage is about 227 volt at the moment.
While typing this post I powered the amp on and within 40 sec. all 4 Led's light up.
I think the line voltage was lower the moment I did the first measurements..
