Loud Buzzing After Using 6SN7 Adapter
Bottle Rocket · 4208
Offline Bottle Rocket
on: June 15, 2015, 01:16:40 PM
I have an issue after using a 12au7 adapter for a 6sn7 tube.  After turning my amp on with the adapter and tube in (and with the headphones plugged in), I heard a loud buzzing coming from my headphones.  I turned off the amp and when I turned it on again with just my regular 12au7 tube, the right channel was out and then both sides started buzzing (very loudly).  I checked my headphones separately and they're okay, so I'm guessing I may have blown something in my Crack.  Any ideas what could be wrong?? (My amp is upgraded with speedball and output caps and everything worked fine before trying out the 6sn7 tube with the adapter).
Reply #1 on: June 15, 2015, 08:06:03 PM
Post any voltages that don't conform with those in the manual.
Reply #2 on: June 16, 2015, 05:39:41 AM
Okay, here are the readings that are off:
Terminal:
1 - 36.35
7 - 153.0
15 - 197.6
21 - 215.8
Offline Chris65
Reply #3 on: June 16, 2015, 06:57:14 AM
Where did you get the adapter? And are you certain it is wired correctly?
Reply #4 on: June 16, 2015, 07:17:21 AM
Terminal:
1 - 36.35
7 - 153.0
15 - 197.6
21 - 215.8
Pull the 6080 and retest terminals 1-5.
Reply #5 on: June 16, 2015, 07:39:46 AM
I got the adapter from a reputable dealer on ebay.  I was told it was 6.3V.  Not sure about the wiring, I'll have to double check with seller.
I pulled the 6080 tube and the voltage readings are:
1 - 37.15
2 - 220.4
3 - 0
4 - 221.5
5 - 74.1
Reply #6 on: June 16, 2015, 07:51:42 AM
Do both diodes on the 9 pin socket glow?  Do you have another 12AU7 that you can use to confirm these results?
Reply #7 on: June 16, 2015, 08:14:59 AM
Looks like the led connected to A8 is not lighting up.  Double checked with two 12au7 tubes.
Reply #8 on: June 16, 2015, 08:41:55 AM
Try jumpering A8 to A3.  If there's a short in the adapter between pins 8 and 9, that would damage the LED pretty quickly.
Offline Chris65
Reply #9 on: June 16, 2015, 04:12:06 PM
You can easily check the adapter wiring using your multimeter. These are the what the connections should be:
12AU7 Pin   wired to 6SN7 Pin
     1                             2
     2                             1
     3                             3
     4                             7
     5                             No Connection
     6                             5
     7                             4
     8                             6
     9                             8
Remember the pins are numbered clockwise from the gap on the 12AU7, from the keyway on the 6SN7 when looking from below.
So when looking at the top of the adapter, the pins will be No.1 to the right of the keyway & then going anti-clockwise from there.
Put one meter lead in the 6SN7 pin1, check it's connected to pin2 on the 12AU7 pins (no resistance), etc
Reply #10 on: June 16, 2015, 04:31:28 PM
Okay, so I jumped A8 to A3 and now the voltages are within correct limits.  So I hooked my headphones up and everything seems to be working properly now.  Thanks a lot!  Any issues that I'll run into with this set up or is there anything else I should do?
Reply #11 on: June 16, 2015, 05:16:29 PM
Yeah, that makes me suspicious of a short inside the adapter.
One working LED makes diagnostics tough, though that shouldn't be an issue if the adapter goes in the round file.
Reply #12 on: June 16, 2015, 05:34:13 PM
So, if I wanted to in the future, could I just replace the blown LED with a new one and remove the jumper?
Reply #13 on: June 16, 2015, 06:28:09 PM
Yes, just be sure it's an HLMP-6000.
Reply #14 on: June 16, 2015, 07:45:07 PM
Okay, great.  Thanks Paul.
