What's next?
Nathan · 4262
Offline Nathan
on: June 24, 2015, 12:21:40 PM
Here's what I've done with my Crack
Speedball
NOS tubes- Tung Sol and Mullard, 5998 and CV4003
Cardas RCA jacks
PEC volume pot
Padded down volume control (metal film resistors)
Bypass audio caps (Russian Teflon)
Bypass 3rd power supply cap (Mundorf film)
Choke in power supply
Uprated  1st and 2nd power supply caps
Switchcraft headphone jack and metal film shunting resistors
PS- quite happy with how my crack sounds- maybe leave well enough alone
« Last Edit: June 24, 2015, 12:23:43 PM by Nathan »
Crack/Speedball & SEX 2.1/C4S
Reply #1 on: June 24, 2015, 12:29:03 PM
A SEX amp.
Offline Nathan
Reply #2 on: June 24, 2015, 12:52:01 PM
Intriguing
Offline ALL212
Reply #3 on: June 24, 2015, 04:43:22 PM
+1 on a SEX amp.
What cans are you listening to?
Aaron Luebke
Offline Nathan
Reply #4 on: June 24, 2015, 04:57:00 PM
HD 600's w/Cardas cable
Offline ALL212
Reply #5 on: June 24, 2015, 04:59:38 PM
Or make the big leap and go Mainline!
SEX + headphones....DAMN!!  And it's a fun build with lot's of upgrade opportunities.  It's a tight build though, not much room once your done for major mods.
Also sets you up for low impedance headphones should you elect to go that route.  My 50 ohm cans will not run on the Crack but SEX handles them perfectly.
« Last Edit: June 24, 2015, 07:09:07 PM by ALL212 »
Aaron Luebke
Offline Rocketman248
Reply #6 on: June 24, 2015, 05:29:23 PM
+2 on the S.E.X.  It's a great amp, and a good companion to the Crack.  And you're set if you decide to start moving into the speaker world.
Be warned, it is a slippery slope. :)
Nick DeBrita
Yokosuka, Japan
Offline JamieMcC
Reply #7 on: June 24, 2015, 09:02:51 PM
Have you thought about trying new cans? T1's make for a very good pairing with a both a hotrodded Crack and the Sex if you build again. The two amps have differing presentations so can compliment each other.  You can also have a lot of fun modding the Sex.
I will add Mainline and HD800 is just gorgeous and a experience worth saving for down the line.
Offline YUL400
Reply #8 on: June 26, 2015, 10:39:41 AM
Speedball
Cardas RCA jacks
PEC volume pot
Try a better fuse Hi Fi Tuning Supreme or Create Audio Deluxe
Offline Nathan
Reply #9 on: June 26, 2015, 02:12:58 PM
I don't understand how a fuse not in the signal path and so early in the power chain that later gets smoothed, buffered and rectified can be improved by a simple fuse
But I am open to an explanation
Offline Aeolus Kratos
Reply #10 on: June 26, 2015, 03:36:56 PM
Audio is a mysterious thing. Sometimes you just can't explain how it works, it simply sounds different  ;D
BTW, I've also used an upgrade Hi-fi Tuning fuse in my Crack, but I can hardly tell the difference  ;)
Offline YUL400
Reply #11 on: June 28, 2015, 05:39:45 AM
Music are vibrations. From the invisible to visible,  from the unknown to the known world, etc. it's vibrations. Fuses are weak links in the ''power chain''. It made quite a difference for me to upgrade from .10 cents fuse to better one. Better transients and lower noise floor from my Crack amp. So experiment !
Reply #12 on: June 28, 2015, 12:35:10 PM
I would love to see measurements of a different fuse contributing to a lower noise floor.
Offline Nathan
Reply #13 on: June 28, 2015, 03:51:37 PM
I doubt you'll see any such measurements
Reply #14 on: June 29, 2015, 03:47:32 AM
You could only get away with posting that on the Bottlehead forum, such nice people that we are. Say that on other "audio" forums and you will go down in a burning ring of fire!   ....and it will burn burn burn..
