Bottlehead Kits
Legacy Kit Products
Quickie
Quickie noise
Quickie noise
mkane
3355
mkane
Full Member
Quickie noise
July 09, 2015, 03:40:08 AM
I tightened the input/output jacks and now I get a big uuuuuuungh, an annoying sound, when everything's switched on. So loud I can't hear any music.
mkane
Full Member
Re: Quickie noise
Reply #1 on:
July 09, 2015, 07:00:31 AM
Problem solved. One of the tubes was bad. Glad I bought a few of those Mullard's.
Global Moderator
Hero Member
Re: Quickie noise
Reply #2 on:
July 09, 2015, 04:38:13 PM
It might just be corroded tube pins or a poor socket connection. Always worth checking!
mkane
Full Member
Re: Quickie noise
Reply #3 on:
July 09, 2015, 05:18:52 PM
Thanks, I'll check. Scotch brite pad work cleaning pins?
Bonzo
Sr. Member
My name is Marco, best known as Bonzo
Re: Quickie noise
Reply #4 on:
July 09, 2015, 08:12:07 PM
Plugging in and out the tube several times can clean a bit the pins.
Ciao!
Bisogna avere orecchio!
Karl5150
Sr. Member
Re: Quickie noise
Reply #5 on:
July 10, 2015, 03:18:55 AM
Also, as noted elsewhere on the forum, plunging in and out of a "magic eraser" type cleaning pad works.
mkane
Full Member
Re: Quickie noise
Reply #6 on:
July 13, 2015, 10:05:48 AM
Thank's for the tip's.
Bottlehead Kits
Legacy Kit Products
Quickie
Quickie noise
