Thinking about S.E.X.
Nathan · 2523
Offline Nathan
on: July 16, 2015, 08:15:55 AM
So I'm thinking about a SEX amp. Already have a Crack which is far from stock which I enjoy tremendously.
Thinking of a 2nd amp- so the SEX comes to mind. Wondering if anyone can recommend some easy mods I should consider right out the gate.
Crack/Speedball & SEX 2.1/C4S
Offline Nathan
Reply #1 on: July 16, 2015, 11:39:00 AM
I do have a Neutrik locking headphone jack lying around which I might use from the start
Offline ZacharyP
Reply #2 on: July 16, 2015, 11:40:41 AM
C4S, and a good attenuator.  The other upgrades (capacitors, potential resistor brand changes, chokes in the power supply, cap bypasses) are matters of taste.
Reply #3 on: July 16, 2015, 11:51:43 AM
The stock jack (made by Neutrik...) disconnects the speakers when headphones are plugged in. Any jack that can't do that is a downgrade.
All mods should be done after an amp is successfully completed. If you never heard the stock amp, you will never know if your mod is an improvement.
Offline Nathan
Reply #4 on: July 16, 2015, 12:17:12 PM
Good points- build stock first
