Bottlehead Kits
Mainline
Input impedance of mainline? (for XLR to RCA adapter)
dubiousmike
3563
dubiousmike
Full Member
July 20, 2015, 10:23:49 AM
Hi all,
I am planning to build an xlr to rca cable to try out the balanced output of my dac with my mainline (as an alternative to the normal se out, which is the product of a summing circuit). To do this, the manufacturer recommends connecting pin 3 to pin 1 in the xlr plug with a resister = to the input impedance of the amp. Diagram here:
https://www.head-fi.org/t/766347/schiit-yggdrasil-impressions-thread/420#post_11774881
Does anyone happen to know the mainline's input impedance? Thanks much!
[EDIT - Jason commented in the thread that although this will not damage the dac, but they do not actually recommend running it this way, contrary to the comments on HF. Scrapping this project as a result.]
Last Edit: August 04, 2015, 10:03:06 AM by dubiousmike
Mike M.
Strikkflypilot
Sr. Member
Shellac fiddler
Re: Input impedance of mainline? (for XLR to RCA adapter)
Reply #1 on:
July 20, 2015, 05:52:57 PM
From the Mainline specs page:"Output power is about 600mW. Input impedance is 25Kohms minimum. Gain is around 12dB into 32 ohm headphones at the low impedance output setting. "
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
dubiousmike
Full Member
Reply #2 on:
July 21, 2015, 04:41:50 AM
Much appreciated!
Mike M.
Bottlehead Kits
Mainline
